JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Camber/ Toe
Camber/ Toe
Camber/ Toe
garyskisplym
11-03-2017, 10:31 AM
I took my car the other day to have the camber and toe adjusted all round as my new front tires are already starting to wear on inside edge.
I got them checked and they where all out.
So the guy adjusted front toe and camber fine.
Went to the rear and that where the problems started.
i cant remember which was it was but one side the toe could not be adjusted and the other the toe could no be done.
Does anyone know what could cause this problem. The mecanic thught that it was a common fault.
What could it be abd what needs replacing??
garyskisplym
11-03-2017, 10:31 AM #1
11-03-2017, 10:44 AM
best person to speak to is tony at wim,
11-03-2017, 10:44 AM #2
11-03-2017, 10:53 AM
It's not just the camber and toe that need checking though. There's the caster too, and that's a key issue on the IS200, plus there are other things that can be checked (lots of other angles to measure).
I would strongly recommend a trip to WIM, they are the experts on this, and they have seen tons of IS200s, including some that have difficulties in being adjusted.
11-03-2017, 10:53 AM #3
99
11-03-2017, 11:47 AM
The NSR toe adjuster cam rides over the ledge it should push against, meaning no adjustment can be had, but......
If they jack the rear up, set the cam neutral and manually push the wheel in the direction desired, then lower the car this will allow adjustment in the other direction.
Historically this problem happens when Positive adjustment is required, do the above then negative direction is required..... Problem solved :wink:
wheels-inmotion
11-03-2017, 11:47 AM #4
11-03-2017, 10:10 PM
See what I mean about a trip to WIM ! :wink: :thumbup:
11-03-2017, 10:10 PM #5
11-03-2017, 11:36 PM
a Trip to WIM will sort all problems mate
11-03-2017, 11:36 PM #6
garyskisplym
12-03-2017, 03:03 AM
wheels-inmotion The NSR toe adjuster cam rides over the ledge it should push against, meaning no adjustment can be had, but......
Thanks for that.
Any idea about the o/s/r camber???
Here the the figures.
Front camber left, right Ok
Front toe right ok Left is at 0.10 (Should be 0.03 to 0.09)
Front toe overall ok
Rear camber left -0.99 (Should bge -0.88 to 0.12)
Rear camber right ok
Rear toe left ok
Rear toe right -0.07 (Should be 0 to 0.12)
This is the data that was given to me by the place that did it.
I would go WIM but its over 500 miles away from me lol.
Edited 23-04-2010, 12:44 PM by garyskisplym.
garyskisplym
12-03-2017, 03:03 AM #7
Thanks for that.
Rear toe left ok
E55EX_RACER
12-03-2017, 03:51 AM
garyskisplym So the guy adjusted front toe and camber fine.
Sounds like they don't know what they're doing TBH, when setting the geo you always start with the rear first (thrust angle) not the front.
E55EX_RACER
12-03-2017, 03:51 AM #8
12-03-2017, 03:56 AM
Mate come down for the OJC meet we have at WIM coming up Tony can explain everything to you, you might even win a free geo or someone might give you the ticket if they win and you ask nicely lol
12-03-2017, 03:56 AM #9
12-03-2017, 05:46 AM
Are those the WIM settings or just the OEM Lexus settings ? Because if they're the latter, sorry but they've wasted your time and money using rubbish settings
12-03-2017, 05:46 AM #10
Views 197
09-02-2024, 08:16 AM
Views 515
27-04-2017, 12:56 PM
Last Post by Namking998
