JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Adjusting camber and toe Problems
garyskisplym
26-04-2017, 01:35 PM
Hi People
The other week i took my car to get a 4 wheels alignment carried out as my tires had started to wear after less then 5k as garage got it done on a 2 wheel system not 4.
All checked for free then i got the phone call and it was all out suprise surprise.
I told them to just do the adjustments, so stood out of the work stop next thing my mate comes out and ask me to come in the mechanic wants to show mw something.
The fronts where all sorted ruffly but that rears where a problem happened.
Cant remember which way it is but one side on the rear they could not adjust the camber and other side could not do the toe.
The mechanic said it was a common fualt on the is200s.
Im just woundering if anyone else has had this problem and if so how do you sort it or what needs replacing??
Gary
garyskisplym
26-04-2017, 01:35 PM #1
Hi People
Gary
26-04-2017, 01:38 PM
adjustable arms are the answer but they not cheap a few people have changed to the adjustable arms but not me yet
26-04-2017, 01:38 PM #2
garyskisplym
26-04-2017, 01:42 PM
is300_dino adjustable arms are the answer but they not cheap a few people have changed to the adjustable arms but not me yet
Is everything not already adjustable on is200??
garyskisplym
26-04-2017, 01:42 PM #3
garyskisplym
26-04-2017, 01:44 PM
DJ Wozza Gary there is only one person to talk to, Tony @ WIM. He will know what you need etc, but the trip will pay for itself as you have already wasted money getting the "tracking" done...
Got it free luckly as no the garage foreman.
Would go to wim but its neally 8hour round trip.
garyskisplym
26-04-2017, 01:44 PM #4
26-04-2017, 01:48 PM
garyskisplym Is everything not already adjustable on is200??
only to a limit, which isnt quite enough after lowering a certain amount then you need the extra from the aftermarket arms
26-04-2017, 01:48 PM #5
garyskisplym
27-04-2017, 10:50 AM
So does anyone know what needed replacing to sort this as you cant even adjust them at the min as the bolts will not move.
garyskisplym
27-04-2017, 10:50 AM #6
Namking998
27-04-2017, 12:56 PM
IMO... The phrase, I think you are looking for Gary is "all the gear and no idea" WIM are the place for sure. But soooooooooooooooooo many people have "lazer 4 wheel alignment" and the car ends up worse than when you started as the operators have no concept of how to use the equipment. Old skool still rules in most instances. Tracking gauge along with a good camber castor gauge. String and bubbles are as good as any high tec machine if the guy (or girl) steering it knows his stuff. There are plenty of cars driving around which are set up correct but, are in reality crabbing down the road. If they cannot even undo the nuts and bolts you have no chance! Move on.
Namking998
27-04-2017, 12:56 PM #7
Views 165
09-02-2024, 08:16 AM
Views 481
29-08-2021, 09:59 AM
Views 219
06-01-2020, 07:01 PM
Views 619
27-06-2019, 10:25 AM
Last Post by Matt_C
Views 375
16-03-2019, 10:07 PM
Last Post by lex2oos
Views 976
04-11-2018, 05:02 AM
Last Post by Stoney
Replies 45
Views 2,152
28-09-2017, 11:48 PM
Views 664
14-03-2017, 12:19 PM
Last Post by garyskisplym
Replies 126
Views 9,010
12-02-2017, 11:30 AM
Last Post by Andy-R.
Views 1,803
23-01-2017, 06:49 AM
