JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Catalytic converter problems
rosey1955
20-06-2019, 12:22 PM
Hi,
Over the past week or so I can smell what I would describe as a slight rotten egg/sulphur smell in the cockpit area of my Lexus IS200 Sport. I have recently changed my Cabin filter and charged the Air Con unit so my guess is that it should not be this. The car has some 140 k mileage. Would you guys reckon that my Cat' Converter is on the way or already shot? I don't intend buying one direct from Lexus.....ideas?:confused1:
rosey1955
20-06-2019, 12:22 PM #1
Hi,
rosey1955
20-06-2019, 12:24 PM
I forgot to add that the smell is normally at start up....
rosey1955
20-06-2019, 12:24 PM #2
20-06-2019, 11:58 PM
found this info on a q&a page from a quick search "Many times on first start-up in the morning, the exhaust may smell like "rotten eggs". This is due to rich fuel condition with a cold engine. However, as the engine warms up, this smell should go away. If it does not, converter damage could possibly follow with extended driving."
try cleaning the intake sensor and giving the ecu a reset to see if it brings the initial fuel load down a bit
20-06-2019, 11:58 PM #3
rosey1955
21-06-2019, 09:41 AM
Thanks. Since posting the thread I have looked at some of the cars previous receipts. On one dated 10/03/2005 it says:
A 49LAB £40.50
REPLACE FRONT CATALIC CONVERTER
K17140-70020 Exhaust manifold £560.55
the rest of the receipt refers tonuts /bolts and gasket /manifold gasket.
Does this mean that the Lexus IS200 has more than one Cat' Converter?
rosey1955
21-06-2019, 09:41 AM #4
A 49LAB £40.50
21-06-2019, 12:19 PM
it has 2 precats in the manifold and 1 in the centre of the exhaust. 3 in total
21-06-2019, 12:19 PM #5
rosey1955
21-06-2019, 12:24 PM
So how would I establish which one is failing?
rosey1955
21-06-2019, 12:24 PM #6
21-06-2019, 12:33 PM
the eggy smell is a sign the cats are working properly, how often do you use your car? you could try givivg it a decent run for an hour or so to heat it up and burn off any buildup from inside the cat.
21-06-2019, 12:33 PM #7
Matt_C
27-06-2019, 10:25 AM
Would Wynss (http://www.halfords.com/webapp/wcs/store...yId_255221) be any use in this situation? Or even, at all?
Matt_C
27-06-2019, 10:25 AM #8
Views 488
29-08-2021, 09:59 AM
Views 225
06-01-2020, 07:01 PM
Views 376
16-03-2019, 10:07 PM
Last Post by lex2oos
Views 977
04-11-2018, 05:02 AM
Last Post by Stoney
Replies 45
Views 2,154
28-09-2017, 11:48 PM
Views 447
27-04-2017, 12:56 PM
Last Post by Namking998
Replies 126
Views 9,097
12-02-2017, 11:30 AM
Last Post by Andy-R.
Replies 39
Views 1,367
10-09-2016, 01:34 AM
Views 1,369
31-08-2016, 08:47 AM
