JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza More Problems.....
More Problems.....
More Problems.....
Pages (4): 1 2 3 4 Next
ibby
07-09-2016, 09:52 AM
Well today
I was excited as my bonnet arrived :thumbup:
so I decided to join bits of the car together...
Raidator to the fans
Radiator Theromstat
Radiator bungs.
plugged in the wiring
Plugged the wiring in... started car and a "pop" noise... everything goes off no lights, so i turn the ignition off and recheck battery terminals..
and put key in, car turns over and starts!
Now on my dash I have
ABS light solid on
Engine check light on
TRC light flashing..
so I let the car warm up and the top pipe gets warm alittle..
but the bottom pipe is solid cold..
I also heard a intermitant tap/tick noise.. (couldnt figure out where it was comming from)
anyone got anyideas ?
ibby
07-09-2016, 09:52 AM #1
Well today
Radiator Theromstat
Radiator bungs.
ABS light solid on
07-09-2016, 10:17 AM
Thermostat faulty?
Check it by boiling a kettle and put the 'stat in and see if it opens?????
07-09-2016, 10:17 AM #2
Thermostat faulty?
ibby
07-09-2016, 10:20 AM
2tongues Thermostat faulty?
Dont have the foggiest.
But the bottom pipe is cold.. and stat is at the bottom of the radiator.. how would thatwork ?
ibby
07-09-2016, 10:20 AM #3
ibby
07-09-2016, 10:34 AM
wouldnt a faulty theromostat... let the temprature needle not move ?
my needle is moving.
ibby
07-09-2016, 10:34 AM #4
07-09-2016, 10:41 AM
the thermostat is at the top.
you may have air in the system.
did you find the reason for the pop?
Have you rechecked the water level?
07-09-2016, 10:41 AM #5
ibby
07-09-2016, 10:49 AM
Sparkystav the thermostat is at the top.
Well, it was getting dark, I looked around.. and couldnt see anything.
it could have been fuel in the cylinder heads.. when it did start.. it smelt of petrol! but after a short while the smelt went away.
I have checked water level. its full to the max!
Isnt it a self bleeding system ?
ibby
07-09-2016, 10:49 AM #6
ibby
07-09-2016, 10:52 AM
I thought the thormostat was at the bottom ?
Can you show me a picture please.
ibby
07-09-2016, 10:52 AM #7
07-09-2016, 11:07 AM
just checked again and your right,
http://www.toyodiy.com/parts/p_E_2001_LE..._1603.html
its at the top on my engine.
07-09-2016, 11:07 AM #8
ibby
07-09-2016, 11:14 AM
You know if our is200 abs sensors do they plug in behind the bumper ? on the inner wings next to the chassis legs ?
ibby
07-09-2016, 11:14 AM #9
ibby
07-09-2016, 11:17 AM
iam using water as a coolant subsitute... that isnt gona cause any bizzar issues with the thermostat desgin ?
ibby
07-09-2016, 11:17 AM #10
Views 533
29-08-2021, 09:59 AM
Views 294
06-01-2020, 07:01 PM
Views 711
27-06-2019, 10:25 AM
Last Post by Matt_C
Views 454
16-03-2019, 10:07 PM
Last Post by lex2oos
Views 1,184
04-11-2018, 05:02 AM
Last Post by Stoney
Replies 45
Views 2,560
28-09-2017, 11:48 PM
Views 515
27-04-2017, 12:56 PM
Last Post by Namking998
Replies 126
Views 10,152
12-02-2017, 11:30 AM
Last Post by Andy-R.
Views 1,588
31-08-2016, 08:47 AM
