JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Power steering problems
James S
06-01-2020, 09:17 AM
Just to add to the long list of problems currently ailing my is200...... When the car is stood or crawling, the power steering is really rough. It judders and is rough as the wheel turns, there is also a sort of grinding noise from the engine bay. :-(
Anyone any ideas?
James S
06-01-2020, 09:17 AM #1
Anyone any ideas?
06-01-2020, 09:23 AM
Is the fluid level ok?
06-01-2020, 09:23 AM #2
James S
06-01-2020, 09:29 AM
Yeah, I drained out the reservoir and refilled with fresh, but still no joy. :-(
James S
06-01-2020, 09:29 AM #3
06-01-2020, 09:35 AM
I assume you checked the belt was tight then as well? Was the level ok before you changed it? Ie no leaks?
Could be the pump vanes maybe worn. Then can be changed but easier buying a secondhand pump,IMHO
06-01-2020, 09:35 AM #4
James S
06-01-2020, 09:42 AM
Yeah the level is fine. Belt doesn't appear worn or loose.
Would it be difficult to fit a new pump?
James S
06-01-2020, 09:42 AM #5
06-01-2020, 07:01 PM
No mate, 2 bolts and a bit of fluid.
06-01-2020, 07:01 PM #6
Views 532
29-08-2021, 09:59 AM
Views 454
02-08-2019, 10:54 AM
Last Post by is300_dino
Views 639
18-07-2019, 11:35 PM
Views 696
27-06-2019, 10:25 AM
Last Post by Matt_C
Views 263
24-04-2019, 02:04 AM
Views 451
16-03-2019, 10:07 PM
Last Post by lex2oos
Replies 25
Views 1,108
14-03-2019, 01:04 PM
Replies 23
Views 1,321
29-01-2019, 03:11 PM
Last Post by jomo
Views 1,176
04-11-2018, 05:02 AM
Last Post by Stoney
