JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza After Market Steering Wheel
JayJay1374
05-05-2019, 01:22 AM
Alright guys, im looking at buying an after market steering wheel, does anyone else have one? with pics?
also looking into getting a boss and i can only find one on ebay?
cheers
JJ
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
05-05-2019, 01:22 AM #1
cheers
JJ
05-05-2019, 04:47 AM
I believe all Toyota are the same so a supra one should do the same job.
05-05-2019, 04:47 AM #2
08-05-2019, 06:19 AM
let me know if you get and fit one i thinking of getting one at some point.
lookatmybiceps
08-05-2019, 06:19 AM #3
JayJay1374
08-05-2019, 09:12 AM
well ive bought a wheel and ive bought this boss off ebay http://www.ebay.co.uk/itm/Steering-wheel...2826113692
so i will update when fitted
JayJay1374
08-05-2019, 09:12 AM #4
JayJay1374
15-05-2019, 12:49 PM
as promised,
[Image: 598866_3896207680150_1222862032_n.jpg]
dead easy to fit, fits perfect!
JayJay1374
15-05-2019, 12:49 PM #5
as promised,
Fire_Fox_69
14-07-2019, 06:03 PM
JayJay1374 as promised,
Where did u get the steering wheel from? And how easy was it to fit?
Fire_Fox_69
14-07-2019, 06:03 PM #6
JayJay1374
15-07-2019, 10:31 AM
I bought the wheel with horn off eBay and bought the boss the wheel sits in from eBay aswell.
There's 2 bolts in the sides of the airbag, after there out the airbag pulls out of the wheel. It then needs disconnecting which is 1 clip. After that there's a big bolt which holds the wheel on. Loosen it but don't take it all the way off. Then pull like hell until the wheel becomes free then remove.
The boss has locating holes for the indicator cancelling so you have to line these up, apart from that the boss bolts on then the new wheel bolts to the boss. The airbag light will be on, if you want this off the bulb needs to be removed from behind the clocks as I couldn't find a resistor to give the resistance the airbag would.
If your gonna do it make sure the battery is disconnected (just incase the airbag goes off) and make sure the wheels are straight before you remove the original wheel.
Edited 25-08-2012, 08:07 PM by JayJay1374.
JayJay1374
15-07-2019, 10:31 AM #7
rob
18-07-2019, 11:35 PM
i would rather have the safety of the airbag than a broken ribcage.
to remove the steering wheel loosen the central retaining nut a few threads and give a strong hit to the back of the wheel to release it.
by pulling you are compressing the steering wheel tilt adjuster.
rob
18-07-2019, 11:35 PM #8
Views 229
28-08-2020, 07:39 AM
Views 483
01-02-2020, 08:22 AM
Views 287
06-01-2020, 07:01 PM
Views 74
03-12-2019, 06:48 AM
Last Post by jasons
Views 276
07-09-2019, 11:47 AM
Last Post by Chris0121
Views 481
25-08-2019, 09:08 AM
Last Post by Matt_C
Views 453
02-08-2019, 10:54 AM
Last Post by is300_dino
Views 717
02-08-2019, 08:39 AM
Last Post by jasons
Views 263
24-04-2019, 02:04 AM
