JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza wheel bearing. its got to be!!!
Jimchap200
29-01-2020, 08:35 AM
Right ive had ongoing issues with a front end whistle. occasionally it progresses to a grinding scraping sound then occasionally treating me to just the whistle.
i bought a used hub assembly and have only just got round to quotes and its been discovered that the abs sensor has been cut instead of disconnected and sent with the part. Theres no chance of me getting the old sensor off the hub cleanly nor will i be able to remove mine ready to connect to the replacement assembly. one thought was to cut my sensor off at the lead and try join the two leads back together....or just buy a new bearing kit and get that fitted. Either of these procedures im not too confident about.
If i purchased a new bearing kit what sort of price am i looking at to get that fitted?
......can anybody help in any way possible please?
many thanks
Jimchap200
29-01-2020, 08:35 AM #1
many thanks
29-01-2020, 08:51 AM
it cost me £100 to get a bearing fitted and another £100 for the bearing.
29-01-2020, 08:51 AM #2
mattlaw
29-01-2020, 12:23 PM
Yeah an look how long it lasted :Chair:
mattlaw
29-01-2020, 12:23 PM #3
29-01-2020, 01:14 PM
yep, I've sent them a grumpy letter. Matt - I've got my timing belt, water pump and two front arms to go on if you're free any time soon? Still waiting on the brake fitting kit and lines, but that's a job for another day.
29-01-2020, 01:14 PM #4
Jimchap200
29-01-2020, 11:07 PM
mattlaw Yeah an look how long it lasted :Chair:
what happened?
Jimchap200
29-01-2020, 11:07 PM #5
what happened?
29-01-2020, 11:55 PM
the previous garage I used did a seriously bad job of fitting it; as such, it's completely disintegrated to the point where the wheel is about to fall off, after less than 2000 miles of use.
29-01-2020, 11:55 PM #6
30-01-2020, 01:10 AM
I would persevere with getting your existing ABS sensor out to be honest. Buy some "Plusgas Formula A" and soak the sensor and the whole area around it in it for a few days. You can sometimes tap the tab the securing bolt goes through very lightly to free it up, so that you rotate the sensor, which breaks the grip the corrosion has on it. I wouldn't try that until after the soaking though as it's easy to break them. I have some rear ones from an LS400 but I doubt they're the same plug (the sensor will be the same).
30-01-2020, 01:10 AM #7
Phil01
30-01-2020, 06:38 AM
^^^ as John said, plenty of plusgas and leave to soak
Phil01
30-01-2020, 06:38 AM #8
Jimchap200
31-01-2020, 10:16 PM
thanks for the info guys....update.... the squeal under speed and my other occasional knock which has been looked at twice to try locate but with everything so called checked and mechanics scratching there heads, drivers side lower ball joint went on the mrs yesterday resulting in a road block and her being stuck with the baby. so very fortunate she was close to home and that it did not happen on her motorway journey today!!! needless to say the cars off the road. not sure if this may have been where the squeak was coming from too though but.....
check ya balljoints guys!!!!
Jimchap200
31-01-2020, 10:16 PM #9
31-01-2020, 10:45 PM
Is your car lowered? Are you using eBay joints? Ormi has had both his go, but his car is quite low!
31-01-2020, 10:45 PM #10
Views 437
16-06-2022, 03:33 AM
Views 180
28-08-2020, 07:39 AM
Views 46
03-12-2019, 06:48 AM
Last Post by jasons
Views 252
07-09-2019, 11:47 AM
Last Post by Chris0121
Views 397
25-08-2019, 09:08 AM
Last Post by Matt_C
Views 353
02-08-2019, 10:54 AM
Last Post by is300_dino
Views 561
02-08-2019, 08:39 AM
Last Post by jasons
Views 552
18-07-2019, 11:35 PM
