JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Wheel stud length for spacers?
ianjw
17-08-2020, 05:20 AM
Looking at putting some spacers on the back end. Nothing huge, just to get the gap similar to the front, something like 10-15mm should do it .
Don't seem to be able to find the standard stud length or anywhere that gives a clue as to what length I might want.
Anyone happen to know the standard length, and/or recommend somewhere to pick up some longer ones?
Thanks
ianjw
17-08-2020, 05:20 AM #1
Thanks
17-08-2020, 08:19 AM
From memory, the standard length is about 48mm, I got some from Fensport that were 65mm but fitting them caused more problems than it solved and I ended up using a 10mm spacer with standard wheel nuts and all was well. 15mm spacing will be pushing it though, I'd go and get a hubcentric spacer if you want that much of a move.
17-08-2020, 08:19 AM #2
ianjw
26-08-2020, 10:18 PM
Cheers. What problems did it cause?
Sent from my Nexus 7 using Tapatalk 4
ianjw
26-08-2020, 10:18 PM #3
28-08-2020, 07:39 AM
None you will encounter with hubcentric spacers and OEM wheels/nuts.
28-08-2020, 07:39 AM #4
Views 484
01-02-2020, 08:22 AM
Views 76
03-12-2019, 06:48 AM
Last Post by jasons
Views 276
07-09-2019, 11:47 AM
Last Post by Chris0121
Views 482
25-08-2019, 09:08 AM
Last Post by Matt_C
Views 462
02-08-2019, 10:54 AM
Last Post by is300_dino
Views 724
02-08-2019, 08:39 AM
Last Post by jasons
Views 646
18-07-2019, 11:35 PM
Views 474
05-01-2019, 08:16 AM
Last Post by P.Lindblom
