JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza heads up regarding steering rack bushes
rob
24-04-2019, 02:04 AM
a quick heads up regarding the steering rack bushes on the IS200/300
the 2 retaining bolts have a 9mm rolled thread with a 8mm shaft - measured and confirmed with a caliper.
so if you buy the solid aluminium replacement versions they have a 10mm hole so you will have 2mm of play relative to bush and bolt.
this can cause a knocking noise.
the rubber OE bushes have the same internal hole but of course no knocking as the rubber absorbs any forces
rob
24-04-2019, 02:04 AM #1
Views 288
06-01-2020, 07:01 PM
Views 454
02-08-2019, 10:54 AM
Last Post by is300_dino
Views 639
18-07-2019, 11:35 PM
Views 427
07-10-2018, 06:34 AM
Views 507
03-10-2018, 08:13 AM
Views 273
02-10-2018, 12:10 AM
Views 647
22-07-2018, 12:08 AM
Views 419
19-03-2018, 03:26 PM
