JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Steering Rack Bushes - IS300 & IS200 the same?
S
21-07-2018, 03:33 AM
hi all,
as above really just wondering does anyone know if the steering rack bushes are the same for the IS300 & the IS200?
if so im going to buy the Figs engineering ones, i would ask figs but i cant imagine he has seen an IS200 before!
thanks
david
S
21-07-2018, 03:33 AM #1
hi all,
thanks
david
rob
21-07-2018, 05:32 AM
yes they are the same, however i do have reservations on the use of the solid passenger side clamp block, i firmly believe that in the longer term it will cause wear and chaffing on the steering rack.
is there any particular reason why you would want solid bushings?
if it was me i would go with a polyurethane bushing kit if you are inclined to go for a firmer feedback, but in all honesty the rack hardly moves when the wheels are rotating
rob
21-07-2018, 05:32 AM #2
21-07-2018, 08:57 AM
As above pointless mod that won't do anything....
21-07-2018, 08:57 AM #3
S
21-07-2018, 10:07 AM
honestly? im just a Figs engineering fan.
from what ive read on MY.IS people couldnt believe the difference it made, ill have to let you all know my own opinion when i fit them.
S
21-07-2018, 10:07 AM #4
rob
21-07-2018, 10:48 AM
if it was me and determined to use the solid bushings i would still retain a rubber or polyurethane U clamp bushing.
be aware you will get move vibration thru the wheel and i suspect this results in a shortened life of the track rod ends.
but hey thats me.
rob
21-07-2018, 10:48 AM #5
but hey thats me.
S
21-07-2018, 11:59 AM
Only the drivers side is a solid bush the passenger side uses a polyurethane belt with a solid clamp
Quote from site:
"Passenger Side: The second of a series of solid bushing kits, this alumium rest is press fit into the crossmember and then the reinforced urethane belt is placed between the stock mounting clamshell bracket."
I'll put a full review up when they arrive and I fit them Smile
S
21-07-2018, 11:59 AM #6
Quote from site:
rob
22-07-2018, 12:08 AM
and its the clamp that will cause wear on the steering rack, as i said i would still keep the original U clmap bush.
but go for it
rob
22-07-2018, 12:08 AM #7
but go for it
Views 331
13-12-2023, 02:06 PM
Views 470
09-11-2023, 03:46 AM
Last Post by Dinho
Views 702
06-11-2022, 01:49 AM
Views 1,199
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,168
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 461
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,724
04-08-2021, 04:34 AM
Last Post by cjoseph
