JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Steering Wheel Very Light very sensitive
wahidhussain
18-09-2018, 06:34 AM
hi all
as title says my steering wheel feels very light it all started a month ago after changing the inner and outer tie rods and links i thought it was the geo so i had it done by wim
and this week i had the control arm bushings changed
the car feels like it's being pushed to the right at speeds 40+ it gets very sensitive
the only thing that i can think of is tyres next because i have 6+ tread on 3 tyres and 1 partworn 3+ tyre on other thats on the front passenger side i put that tyre on before get the Geometry done
so my question is could it be tyre related?
thanks
wahid
wahidhussain
18-09-2018, 06:34 AM #1
hi all
thanks
wahid
19-09-2018, 01:20 PM
My guess would have been incorrect geometry settings after the suspension components were changed, but if you had them set by WIM after the installationg then I very much doubt there is anything wrong with the geometry.
I don't think it would have anything to do with the tyres though personally.
19-09-2018, 01:20 PM #2
19-09-2018, 01:35 PM
swap the wheels round and see what it feels like
19-09-2018, 01:35 PM #3
wahidhussain
19-09-2018, 02:32 PM
sprinter2012 My guess would have been incorrect geometry settings after the suspension components were changed, but if you had them set by WIM after the installationg then I very much doubt there is anything wrong with the geometry.
hi mate
i had the geometry done after the suspension components were changed and asked tony about the control arm bushings he said it wouldn't affect the geometry
thanks
is300_dino swap the wheels round and see what it feels like
i try that too
thanks
wahidhussain
19-09-2018, 02:32 PM #4
hi mate
thanks
i try that too
thanks
wahidhussain
19-09-2018, 02:34 PM
[quote=wahidhussain]hi mate
thanks
i try it mate
thanks
wahidhussain
19-09-2018, 02:34 PM #5
thanks
i try it mate
thanks
168
20-09-2018, 11:59 AM
have you checked the tyre pressures?
northernmonkey
20-09-2018, 11:59 AM #6
wahidhussain
20-09-2018, 02:11 PM
northernmonkey have you checked the tyre pressures?
ya mate 35ps in all
wahidhussain
20-09-2018, 02:11 PM #7
ya mate 35ps in all
rob
24-09-2018, 01:36 AM
what type of cntrol arm bushing did you use? was it the solid polyurethane type or the rubber hardrace?
If it was hardrace then you need to make sure when the bushing was installed it was in the correct orientation.
rob
24-09-2018, 01:36 AM #8
wahidhussain
26-09-2018, 05:20 PM
rob what type of cntrol arm bushing did you use? was it the solid polyurethane type or the rubber hardrace?
hi mate
ya i think it was the solid polyurethane one heres the link
http://www.ebay.co.uk/itm/00-05-Lexus-IS...58905ca3c3
wahidhussain
26-09-2018, 05:20 PM #9
hi mate
Views 388
25-06-2021, 08:14 AM
Views 233
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 400
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 240
16-09-2020, 08:21 AM
Views 180
28-08-2020, 07:39 AM
Views 284
30-07-2020, 12:35 AM
Last Post by Dinho
Views 235
28-03-2020, 10:39 PM
Last Post by James S
Views 369
10-03-2020, 11:17 AM
Views 243
10-03-2020, 08:16 AM
Last Post by Colin G
Views 371
01-02-2020, 08:22 AM
