JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Steering wheel removal
rob
03-10-2018, 12:12 AM
Hi all, are any special tools needed to remove the steering wheel? A pulled etc?
Is there a guide somewhere?
I need to take it off as the block in-between the wheel and shroud is loose and making noise.
[Image: 3e9eedcb.jpg]
Anyone know what it is?
Sent from my stupid iPhone
rob
03-10-2018, 12:12 AM #1
rob
03-10-2018, 12:21 AM
I of course mean puller and not pulled
rob
03-10-2018, 12:21 AM #2
03-10-2018, 01:17 AM
You probably could use a puller, but I've always just undone the nut, then wound it back on 2 turns and yanked the steering wheel towards me until it came loose (apart from the first time, when I smacked myself in the face with the wheel when it came off).
Edited 14-11-2011, 10:52 AM by toxo.
03-10-2018, 01:17 AM #3
rob
03-10-2018, 01:49 AM
Ok thanks. I found a good guide on my.is for the removal few mins ago so will give the yanking method a go and report back this evening.
rob
03-10-2018, 01:49 AM #4
03-10-2018, 01:50 AM
You could be a bit more scientific and tap it from behind with a mallet or something I suppose? Smile You only need to loosen it from the splines.
Edited 14-11-2011, 11:25 AM by toxo.
03-10-2018, 01:50 AM #5
03-10-2018, 02:02 AM
I don't imagine it will be too hard to get off, shouldn't need any special tools etc. I have never had any problems in other (similar aged Toyota) cars, though not tried an IS. Though I will soon, as mine is very worn and I have a lower mileage one to fit.
03-10-2018, 02:02 AM #6
03-10-2018, 07:13 AM
I agree with Toxo, i always use the loosen and yank method. works a treat, takes a few yanks though
03-10-2018, 07:13 AM #7
rob
03-10-2018, 08:13 AM
Ho guys ok I tried the yank but no chance. Borrowed a puller and it popped straight off. The loose part is for the airbag activation as works like a child proof bottle cap somehow it came a bit loose. Installation instructions are on the unit to just tightened if a bit and is ok for now.
rob
03-10-2018, 08:13 AM #8
Views 230
28-08-2020, 07:39 AM
Views 483
01-02-2020, 08:22 AM
Views 287
06-01-2020, 07:01 PM
Views 75
03-12-2019, 06:48 AM
Last Post by jasons
Views 238
23-10-2019, 03:14 PM
Last Post by Jk 200sx
Views 276
07-09-2019, 11:47 AM
Last Post by Chris0121
Views 481
25-08-2019, 09:08 AM
Last Post by Matt_C
Replies 25
Views 1,385
08-08-2019, 01:11 PM
Views 454
02-08-2019, 10:54 AM
Last Post by is300_dino
