JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! Repositioning Horns on an Lexus IS200
Pages (5): 1 2 3 4 5 Next
09-05-2016, 08:53 AM
After installing a Sport grille, the horns on the IS200 become a lot more obvious than before, and can be IMHO a bit of an eyesore. This isn't the best picture, but then the light isn't shining directly on the front :
[Image: horns1.jpg]
However, it's very easy to reposition them. There are several holes on the inside of the crash bar that you can simply screw the horns into, you can see two in this picture :
[Image: horns2.jpg]
Edited 16-09-2009, 12:50 PM by steviewevie.
09-05-2016, 08:53 AM #1
[Image: horns1.jpg]
[Image: horns2.jpg]
What you will need are two bolts and two washers. I used some that I found in my collection of bits and pieces, I *think* they are M6 bolts, and as you can see they are not very deep. The washers are M6 washers.
[Image: horns3.jpg]
[Image: horns4.jpg]
[Image: horns5.jpg]
Remove the grille (this makes it easier, although some members have successfully moved their horns with the grille still in place), then the horns can be easily unbolted from their existing positions.
[Image: horns6.jpg]
Edited 16-09-2009, 12:51 PM by steviewevie.
09-05-2016, 08:53 AM #2
[Image: horns3.jpg]
[Image: horns4.jpg]
[Image: horns5.jpg]
[Image: horns6.jpg]
09-05-2016, 08:54 AM
The OEM bolts used seem just slightly too big to fit into the holes on the crash bar, hence the new bolts being required. Fix the horns onto the crash bar with the new bolts, using whichever holes seem easiest for positioning given the wires etc. You will need to bend the horns slightly away from the crash bar so that the horns themselves aren't touching (only the bracket). If you don't do this, the horns will make a horrible/faintly amusing noise.
[Image: horns7.jpg]
[Image: horns8.jpg]
The end result is a lot cleaner and pleasing, to my eye at least :
[Image: horns9.jpg]
Edited 16-09-2009, 12:52 PM by steviewevie.
09-05-2016, 08:54 AM #3
[Image: horns7.jpg]
[Image: horns8.jpg]
[Image: horns9.jpg]
09-05-2016, 08:57 AM
Well explained Steve lets see some more tips
09-05-2016, 08:57 AM #4
aaronabbott
09-05-2016, 09:29 AM
good job steve yet another job for a weekendSmile
aaronabbott
09-05-2016, 09:29 AM #5
13-07-2016, 04:33 AM
Ok thats me just moved my horns now :drool:
Only thing is I cant get my grill to locate into all the clips but its still ok :ohmy:
13-07-2016, 04:33 AM #6
Jambo
13-07-2016, 04:51 AM
Had trouble with one of them at JAE. Maybe somebody can sort it for you. Its very tricky Smile. And good tutorial Stevie
Latest Meets
Ace Cafe 16/10/10,
Jambo
13-07-2016, 04:51 AM #7
Latest Meets
Ace Cafe 16/10/10,
13-07-2016, 05:37 AM
i moved my horns quite a while back and it looks alot better now
13-07-2016, 05:37 AM #8
cameron
13-07-2016, 10:07 AM
think i will do that this weekend.mind prob need to take my tte bumper off again.should have done this when i had the bumper off to spray the mesh oh well :Chair:
[Image: 25042008020-1.jpg]
cameron
13-07-2016, 10:07 AM #9
cameron
09-08-2016, 04:22 AM
did mine also looks so much better.:thumbup1:
cameron
09-08-2016, 04:22 AM #10
Views 218
13-12-2022, 05:57 AM
Replies 46
Views 7,759
16-03-2022, 12:02 AM
Last Post by Emissary
Views 888
10-09-2021, 01:07 PM
Replies 25
Views 4,931
18-08-2019, 06:32 AM
Last Post by Johny47
Views 583
24-01-2019, 02:06 PM
Views 2,173
03-10-2018, 08:33 AM
Views 926
04-09-2018, 10:45 AM
Replies 24
Views 2,434
19-07-2018, 10:57 AM
Views 849
23-01-2018, 07:18 AM
Last Post by Jambo
