JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! How to tell if your IS200 has an LSD or not
Pages (5): 1 2 3 4 5 Next
18-05-2016, 08:18 AM
This is a common question, regarding how to tell if a particular IS200 has a limited-slip diff or not. This can be tricky, e.g. Sport models should have them, but it's not always obvious if a car is a Sport or is an S/SE with added bits.
The sure way to tell is to check the manufacturer's VIN plate, located on the bulkhead at the back of the engine bay. Here's a picture of mine :
[Image: IMG_2649_edited-1.jpg]
The bottom line is the relevant one here. This is a coding that represents the paint code/trim/transmission etc. The specification of the "axle" is represented by the third group of characters. It will say either A02A or A02B. If it says "A" it's an open diff, and "B" means it's an LSD. Mine says "A02B" so it has an LSD.
Just for interest, on mine the first bit is the paint code (1C0 - Platinum Ice), I don't know what the second bit is for, think it's the trim (LB20), the third bit is the "axle" (above), and the fourth bit is the gearbox (J160 manual gearbox).
Of course, all this is about whether your car has a factory-fit LSD. It's possible that someone could have changed the diff as an after-market modification.
Edited 03-07-2009, 12:05 PM by steviewevie.
18-05-2016, 08:18 AM #1
29-12-2016, 02:24 PM
steviewevie This is a common question, regarding how to tell if a particular IS200 has a limited-slip diff or not. This can be tricky, e.g. Sport models should have them, but it's not always obvious if a car is a Sport or is an S/SE with added bits.
Ok but how would you know if it was not attached to a car and say it was on ebay or in a breakers
29-12-2016, 02:24 PM #2
29-12-2016, 02:39 PM
Moley Ok but how would you know if it was not attached to a car and say it was on ebay or in a breakers
the only way is to take the back off and have a look mate
29-12-2016, 02:39 PM #3
29-12-2016, 02:51 PM
yip because of the type of diff turning one side and watching for the other side going the same way doesn't work...unless you can spin it very very fast.lol
29-12-2016, 02:51 PM #4
29-12-2016, 02:53 PM
Sparkystav the only way is to take the back off and have a look mate
And what would you see :tongue_smilie:
29-12-2016, 02:53 PM #5
29-12-2016, 02:57 PM
Moley And what would you see :tongue_smilie:
on a LSD you'd see
[Image: DSC00378-1.jpg]
basically on both you'll see the same thing in the middle, but the LSD will have little cogs inside of it you can see through holes in the side. the normal one wont have little cogs
Edited 10-02-2010, 12:33 AM by Sparkystav.
29-12-2016, 02:57 PM #6
on a LSD you'd see
29-12-2016, 03:00 PM
something that looks like this
[Image: DSC00378.jpg]
29-12-2016, 03:00 PM #7
29-12-2016, 03:02 PM
Ok cheers for that , all we need to do is find one
29-12-2016, 03:02 PM #8
29-12-2016, 03:04 PM
Thats a bit spoookeeeeeeeeey both of yous posted the same pic
29-12-2016, 03:04 PM #9
29-12-2016, 03:09 PM
lol its my pic from when i took mine apart!
29-12-2016, 03:09 PM #10
Views 182
13-12-2022, 05:57 AM
Replies 25
Views 4,576
18-08-2019, 06:32 AM
Last Post by Johny47
Views 521
24-01-2019, 02:06 PM
Views 2,001
03-10-2018, 08:33 AM
Replies 24
Views 2,154
19-07-2018, 10:57 AM
Replies 41
Views 3,055
09-04-2018, 11:19 PM
Last Post by IanS200
Views 802
23-01-2018, 07:18 AM
Last Post by Jambo
Views 2,167
27-10-2017, 06:14 AM
Views 1,342
28-08-2017, 12:18 PM
