JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza gearbox seals
gearbox seals
gearbox seals
wahidhussain
05-05-2017, 11:06 AM
hi all
am changing my clutch next week
and i wanted to know do i need new seals for box or the old one be ok?
and how meny are there one or two?
thanks
wahid:thumbup:
wahidhussain
05-05-2017, 11:06 AM #1
hi all
thanks
wahid:thumbup:
05-05-2017, 11:23 AM
I didnt think there was any seals to change mate as its dry round the clutch area
05-05-2017, 11:23 AM #2
05-05-2017, 11:25 AM
their is a seal (its on the shaft that goes through the clutch but to replace it involves a full box strip down.......
unless its leaking dont touch!!!
05-05-2017, 11:25 AM #3
wahidhussain
05-05-2017, 11:37 AM
thanks guys
i ment the for the transmission oil so i can use the old nut or seal? for that
thanks
wahid
wahidhussain
05-05-2017, 11:37 AM #4
thanks guys
thanks
wahid
05-05-2017, 12:00 PM
yes the nut and washer are desighned to be used more than once
05-05-2017, 12:00 PM #5
06-05-2017, 02:47 AM
ormi their is a seal (its on the shaft that goes through the clutch but to replace it involves a full box strip down.......
Thats the seal that went on my old Lexus 'box, when it wasn't fitted anywhere near correctly by TGT, caused clutch failure and a broken thrust bearing................ cheaper just to put a new 'box in.
06-05-2017, 02:47 AM #6
wahidhussain
06-05-2017, 06:14 AM
Sparkystav I didnt think there was any seals to change mate as its dry round the clutch area
ormi yes the nut and washer are desighned to be used more than once
thanks guys:thumbup1:
wahidhussain
06-05-2017, 06:14 AM #7
Views 184
05-10-2020, 03:00 PM
Views 402
04-08-2019, 10:02 AM
Last Post by sprinter2012
