JVC AVX810 DVD/SD Card/USB/IPOD + Bluetooth
For sale again is my 7in Touch Screen Double DIN JVC AVX810 DVD unit. It has an inbuilt SD card slot, USB Input (which will also run a pre-video Ipod) + the KS-BTA200 Bluetooth adaptor.
Will also include a full fitting kit for the IS200/300 including bypass cable and Autoleads fascia adaptor.
If someone was to come and pick it up I will fit it for free (to an IS200/300)
£300 + Postage
has this actally got a dvd slot??
Quote:The JVC AVX810 in-dash multimedia DVD player will bring high performance and options galore to the double-sized dash opening in your vehicle. The AVX810 versatile player combines a unique detachable 7 inch screen, touch screen controls and playback of music and video from disc or portable device.
Enjoy movies with JVC AVX810 including DivX and other formats on the wide 7-inch touch panel monitor featuring Proximity Sensor with a new sensation of AV control, and 9-language display. You can play audio and video from your iPod, USB devices, or SD cards, and even fine tune the soundscape with 7-band iEQ. The unit is also compatible with Bluetooth Wireless Technology and DAB Radio with optional devices.
JVC AVX810 Features:
* MOSFET 50W x 4 Max
* Built-in 7.0-Inch Wide Monitor
* Proximity Sensor/Touch Panel
* Detachable front panel for security
* SD Card Slot
* USB Port
* GIGA MP3 MULTI (allows MP3 tracks to be played back from a DVD disc)
* 192kHz/24-bit Audio DAC (DVD-Audio)
* 7-Band iEQ
* USB control for Colour Screen iPods (KS-PD100 IPOD adaptor required from early models)
* DVD-Audio Compatible
* WAV Compatible
* MP3/WMA Compatible with ID3/WMA Tag
* DVD-R/-RW, +R/+RW, VCD Compatible
* Multi-Border DVD Compatible
* CD/CD-R/CD-RW Compatible
* AAC compatible
* DivX Ultra / JPEG Playback / MPEG 1.2 compatible (DVD/CD/USB)
* Bluetooth compatible
* DAB control with optional KT-DB1000
* 5.1-Channel DTS/Dolby Digital/Dolby Pro Logic II/2ch MPEG Decoder Built-In Time Alignment (5.1ch)
* Gold-Plated RCA Line Output Terminals (x 2 pairs)
* Gold-Plated Center-Channel Output Terminal
* Gold-Plated Video Output Terminals
* Gold-Plated 5V Subwoofer Output Terminal with Level/Frequency Control
* Second Gold-Plated Audio Output Terminals
* Gold-Plated AV Input Terminals
* AV-BUS Input
* Detachable Motorised Slide-Out Face
* Multi-Function Wireless Remote Control
* Headphone Surround
* Shock Proof Memory
* Headphone surround
* Shock proof memory
* Wall paper setting
* Amp defeat switch
* Steering wheel remote control ready (optional adaptor required)
* Rear view camera ready
JVC KS-BTA200 Bluetooth Adapter
Add hands-free calling to your compatible JVC receiver. This handy JVC Bluetooth adapter lets you answer incoming calls and place outgoing calls with compatible phones. You can also stream music from a phone with MP3 storage to your stereo.
The KS-BTA200 includes a pass-through port that allows you to connect it to your JVC receiver while retaining your existing JVC iPod adaptor, DAB tuner, or CD changer.
* Bluetooth wireless adapter for JVC receivers with J-Bus connections
* Place and accept calls hands-free via the wireless connection
* Audio routed via JVC car stereo
* Voice recognition dialing with supporting mobiles
* Supports audio streaming from Bluetooth devices
* Digital technology ensures crisp, static-free performance
* Included microphone
More info on this unit.....
* SD Card Slot
* USB Port
* 7-Band iEQ
* WAV Compatible
* AAC compatible
* AV-BUS Input
* Amp defeat switch
Yep would install it in the Leon but its £200 for the fitting kit as you have to buy the satnav centre console due to having the relocate the climate control. Otherwise i would 100% keep this unit.
Unit has DVD and SD Card slot behind the motorised monitor and an External USB input that is long enough to sit in the glove box.
Bluetooth unit has external mike which has a cable long enough to put anywhere near the driver (I had mine just to the right of the drivers sun visor.)
EASY to fit mate, just follow the very simple precautions. Probably allow 1 hour to do it. The Amp cable is the hardest bit.
