JapCarForum Cars, Cars, Cars! General Car Maintenance Mitsubishi Evo Buying Guide
Pages (6): 1 2 3 4 5 6 Next
03-06-2017, 01:11 AM
If you want one of these high performance vehicles then please get some help when purchasing them as these can be a very expensive vehicle to run.
By doing it right you could save yourself many hundreds or thousands of pounds.
All ways were possible buy these from a dealer who specialised in this sort of vehicle and can offer you a worth while warrenty
As many have been up graded with many different modifications things light bigger brakes exhaust Suspension.
Also remember that you will always pay more for a FQ as this has more power than the low powered 260 bhp version
The RS version give a very hard daily drive so think about what you want from a evo before buying one.
A full service history should be a must and check with the dealer that have stamp the owners book.
The Evo are very expensive to insurance so add this into your budget along with service costs
Make sure the cars have the cat fitted or you will fail your MOT.
Evo 46g3 units are very tough as long as they are serviced Oil changes are done at 4500 miles with plugs and timing belts done every 45,000 miles.
Evo standard boost pressure is set at 1.2 bar for the Evo IV and just under 1.0 bar on the early Evo 1>3
Always stay away from a car that dash board light stay on as every light in this area should be off when pulling away from stand still.
Most Evo clutches are not very strong and can wear out quickly.
Gearboxes can also wear out and can be difficult in 1st 2nd and 5th gear and watch out for the gearbox whining. And as you're already guessed are not cheap to change.
Evo have had recalls over the years so please check that they have had all outstanding work carried out by chatting with your dealer.
LSD Can also cost a lot to repair upwards of £1800
Also check that the ACD PUMP is working properly it should have a green light when switching between snow/ gravel and tarmac.
Check tyre wear for the car geometry all tyres should wear even.
Break fluid should be changed every 18,000 miles most EVO have had their brake up graded so have them checked.
Rust can be found on the boot lids and suspension first so this should be your starting point when checking for rust.
Take care when making a purchase of any performance car as these can often be expensive mistake if you do not done your homework.
03-06-2017, 01:11 AM #1
09-06-2017, 12:07 PM
its not uncommon for clutches only to last 2500 miles!!!my friend destroyed one after 20-30 launches!!!!!
why not go for a volvo t6???more room for the kids and faster than the evos better on fuel than the evo,the evo is slightly faster through the corners though..
thats why the traffic up here got rid of the evos....to much to run and not as fast as the volvo!!!shocked i was......
09-06-2017, 12:07 PM #2
09-06-2017, 12:23 PM
Volvo is not as fast as the Evo the quickest engine Volvo have is in the Ford Focus RS
09-06-2017, 12:23 PM #3
09-06-2017, 01:04 PM
Lexusboy Volvo is not as fast as the Evo the quickest engine Volvo have is in the Ford Focus RS
side by side from a rolling start(off a round about) the volvo is off leaving the evo.............
09-06-2017, 01:04 PM #4
09-06-2017, 01:05 PM
ormi side by side from a rolling start(off a round about) the volvo is off leaving the evo.............
speak to a traffic boy who has driven them both and they'll tell you the same....
its not all about bhp gear ratios play a factor as well....
09-06-2017, 01:05 PM #5
09-06-2017, 01:13 PM
and nope its not thats a poor engine......
police t6's come with the new straight six twin scroll turbo with a simple remap by volvo which pushes the police volvo past the 350 mark..the wife just text the inspector...
09-06-2017, 01:13 PM #6
10-06-2017, 07:12 AM
ormi and nope its not thats a poor engine......
Evo vs Volvo
http://www.youtube.com/watch?v=_bKYludxZEs
Supra vs Volvo
http://www.youtube.com/watch?v=0ReaHyJ0m...re=related
10-06-2017, 07:12 AM #7
Evo vs Volvo
Supra vs Volvo
10-06-2017, 08:33 AM
well those videos settle it you want a fast car buy a volvo!!
10-06-2017, 08:33 AM #8
10-06-2017, 08:36 AM
Well if you need to take your Labrador out for a walk and you don;t have much time.................
If you want to look good stay Jap.........
10-06-2017, 08:36 AM #9
10-06-2017, 09:26 AM
some of the volvo owners do a few not to expensive mods turn up the boost and are running 400-600 bhp!!!!on standard insides!!!!!!!!
10-06-2017, 09:26 AM #10
Views 2,564
06-12-2018, 12:58 AM
Last Post by speedview
Views 1,592
25-06-2018, 12:05 AM
Last Post by Stoney
Views 608
11-08-2017, 04:40 AM
Views 1,844
08-07-2017, 08:18 AM
Last Post by Bobby
Views 472
07-07-2017, 10:24 PM
Views 603
03-06-2017, 01:34 AM
Views 759
07-05-2017, 03:47 AM
Views 1,405
01-04-2017, 03:03 AM
Last Post by Mikey
