JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Help - Power Steering Hose
06-08-2017, 09:52 AM
OK, time to own up, changed both my belts on the car today but it looks like I must have moved the power steering pipe whilst doing it, the bottom pulley has nicked the PS pipe and just ****** all my fluid over the engine bay :Chair:
What I need to know is if it is possible to put a joint piece in or does the whole pipe have to be replaced?
Used cranes years ago and we used to stick a joint piece in and that was good enough, they had a lot more pressure in them than a car PS system.
Any help at all would be appreciated Smile
Todd
Toyota Altezza Z Edition.
06-08-2017, 09:52 AM #1
Todd
06-08-2017, 01:39 PM
Well looks like I'm getting trailered home Sad
Can't find a garage that'll be open on a Saturday here in Oban so got to get the RAC to trailer me all the way back to Edinburgh!!
Booooo
06-08-2017, 01:39 PM #2
Booooo
Chri5
06-08-2017, 01:48 PM
can you remove the pipe???
if so take the pipe to a hydraulic company and ask them to put a join in.
Chri5
06-08-2017, 01:48 PM #3
06-08-2017, 01:50 PM
Wouldn't be an issue if I was back at home but it's a bit like the wild west in Oban, chances of getting anything done on a weekend are zero Sad
06-08-2017, 01:50 PM #4
Phil01
Try these todd.
http://www.pirtek.co.uk/service-centre-locator.aspx
Phil01
06-08-2017, 01:50 PM #5
Try these todd.
06-08-2017, 01:53 PM
Cheers Phil, none on the west coast at all Sad
06-08-2017, 01:53 PM #6
Phil01
06-08-2017, 01:58 PM
typical mate, is the hole on metal pipe or the rubber hose??
Phil01
06-08-2017, 01:58 PM #7
06-08-2017, 02:01 PM
Just the rubber hose, tempted just to measure the interior of the pipe and go down to the ironmongers and get a joint piece and a couple of hose clamps LOL
06-08-2017, 02:01 PM #8
Phil01
06-08-2017, 02:16 PM
do you know if its a Hi pressure pipe or low pressure Return to the reservoir, if its low then leakage is less of a problem,
you can get barbed hose couplers that resist being "blown apart"
http://www.made-in-china.com/showroom/zj...1056-.html
I know this website is in china, but was only using image for example
Phil01
06-08-2017, 02:16 PM #9
06-08-2017, 02:33 PM
The hose that the smallest white bubble is on, not sure which one it is?
[Image: clean%20engine.jpg]
06-08-2017, 02:33 PM #10
Views 417
27-02-2019, 08:16 AM
Last Post by S
Views 343
02-09-2018, 11:45 AM
Views 1,617
15-04-2018, 04:48 AM
Replies 24
Views 1,221
23-07-2017, 11:41 AM
Last Post by Dan_Turism0
Views 960
30-04-2017, 03:02 AM
