JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza help finding part numbers
26-08-2018, 12:40 PM
well i'm looking for part numbers for a 1g gte. need the piston ring seals if thats what they call them
26-08-2018, 12:40 PM #1
26-08-2018, 01:37 PM
The piston rings?
13011-88341
or 13013-88341 for 0.5 oversized!
their for a full set,
26-08-2018, 01:37 PM #2
The piston rings?
13011-88341
26-08-2018, 02:51 PM
not sure if thats what they call them. do you know the ones i want to use to do the 1g gte to 1gfe pistons and rods swap.
26-08-2018, 02:51 PM #3
26-08-2018, 03:22 PM
The rings that go round the side of the piston?
then thats the part numbers
26-08-2018, 03:22 PM #4
26-08-2018, 03:25 PM
whats the difference with the normal to oversized. and whats best for me. i'm going to put the 1g gte pistons in my 1gfe engine. also is there anything else i should change or use.( cam or valves etc)
i know i need a new head gasket when i do this but what about bearings etc
26-08-2018, 03:25 PM #5
26-08-2018, 03:54 PM
Replace the big end bearings for sure!!
Exhaust and inlet manifold gaskets, unless you can get the head off without disturbing them.
You may have to physically measure the bore, to get the correct rings. If you are sure the bores haven't been honed before then I would think standard rings would fit? But best to measure.
It may be that you whip the head off and find the bores need honing anyway, score marks etc? Could be worth a PM to Silverline though??
26-08-2018, 03:54 PM #6
26-08-2018, 04:01 PM
thanks man. want to push the car up in the new year. looking to push 400+
26-08-2018, 04:01 PM #7
26-08-2018, 04:06 PM
So long as it is working on the 17th thats all that matters for the momentConfusedcared:
26-08-2018, 04:06 PM #8
26-08-2018, 04:09 PM
it's on the dyno as i type. should be picking it up in the day tomorrow if there is no more little problems to solve. new cat and everything was going great today when i last messaged him. will ring now and find out how it's going
26-08-2018, 04:09 PM #9
26-08-2018, 04:16 PM
Fingers crossed for you buddy.
26-08-2018, 04:16 PM #10
Views 418
07-10-2021, 07:35 AM
Last Post by Stoney
Views 488
29-06-2021, 12:10 PM
Last Post by jj260z
Views 491
31-12-2020, 01:51 PM
Last Post by jomo
Views 672
22-06-2020, 11:14 AM
Last Post by S
Views 1,302
06-06-2020, 07:50 AM
Last Post by S
Views 1,268
26-04-2020, 01:54 AM
Views 942
15-12-2019, 08:42 PM
Last Post by jomo
Replies 23
Views 2,632
08-09-2019, 04:40 PM
Last Post by jimxms
Views 1,628
19-07-2019, 01:14 PM
