JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Nuts!!!!
Nuts!!!!
Nuts!!!!
jomo
24-09-2017, 02:37 PM
Found these on ebay, maybe getting my sefl a set as mine are looking a bit shot!!
http://cgi.ebay.co.uk/20-x-ALLOY-WHEEL-N...3361cc5ca7
jomo
24-09-2017, 02:37 PM #1
Fry-Up
24-09-2017, 03:06 PM
do you have original alloys on? cos the original nuts aren't tapered and i'm unsure if that matters, I have tapered ones on my aftermarket rims but the holes are tapered to match
Fry-Up
24-09-2017, 03:06 PM #2
Phil01
24-09-2017, 03:22 PM
If you got standard 17inch alloys these will not fit. these are tapered type, You need the shouldered nut with built-on washer, as it is the shouldered nut that fits the wheel true, not the hub,
http://www.bargaincarrims.com/shank-lug-nuts.php
Phil01
24-09-2017, 03:22 PM #3
Phil01
24-09-2017, 03:25 PM
The correct nuts for standard OEM alloys,
http://cgi.ebay.co.uk/Lexus-alloy-wheel-...1692wt_905
Phil01
24-09-2017, 03:25 PM #4
Fry-Up
24-09-2017, 03:26 PM
thought so, the seller u linked mentions the flat seated nuts further down his ad, those are the ones u need
Fry-Up
24-09-2017, 03:26 PM #5
jomo
25-09-2017, 06:13 AM
Ok, cheers lads. I'll recheck the sellers ad!
jomo
25-09-2017, 06:13 AM #6
Views 927
06-10-2018, 03:28 AM
Views 675
15-03-2018, 01:46 AM
Last Post by reganlives
Views 408
02-03-2018, 08:39 AM
Last Post by sprinter2012
Views 811
11-06-2016, 06:26 AM
Last Post by edeath
