JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza am i being stupid?
am i being stupid?
am i being stupid?
Dave
05-10-2017, 03:02 PM
I though screenwash was suppose to work in cold weather and not freeze up.
Dave
05-10-2017, 03:02 PM #1
05-10-2017, 03:03 PM
Well remember it is half water so it will freeze, you have to change the type or use it stronger
05-10-2017, 03:03 PM #2
Dave
05-10-2017, 03:16 PM
thats a yes then lol. i will use in neat next time. see if that helps
Dave
05-10-2017, 03:16 PM #3
beyondhelp
05-10-2017, 05:44 PM
Usually tells you what ratio to mix it to vs freezing point etc...
beyondhelp
05-10-2017, 05:44 PM #4
05-10-2017, 11:42 PM
Yeah, check what it says on the bottle as to what ratio vs water you're supposed to use, depending on the temperature.
05-10-2017, 11:42 PM #5
05-10-2017, 11:43 PM
Oh, just to add - even if you have non-freezing screenwash, that won't stop your washer jets freezing up. Some cars have heated jets to stop this happening, but not the IS200/300.
05-10-2017, 11:43 PM #6
06-10-2017, 08:56 AM
I tried a heated screen wash method years ago, it worked well enough but as hot water SOMETIMES freezes faster then cold water this didn't work to well!!
06-10-2017, 08:56 AM #7
Phil01
06-10-2017, 08:58 AM
was it a little heat exchanger that you plumbed into your heater pipes??
Phil01
06-10-2017, 08:58 AM #8
06-10-2017, 09:00 AM
Thats the one!!
Simple and effective, but its got to go before the thermostat, otherwise it doesn't work untill engine is at operating temp.
06-10-2017, 09:00 AM #9
Thats the one!!
Replies 23
Views 1,163
24-04-2018, 03:03 AM
Last Post by jimxms
