JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza GRRRR stupid ECU bolts!!!
Pages (3): 1 2 3 Next
12-04-2018, 11:33 AM
Was trying to get access to my ECU harness this evening but I couldn't pull the connectors out of the ECU as there's a stupid metal cover over the top of the ECU.
Its screwed in place with four torx security bolts (star shaped with the little nipple in the middle), but even though I've got a full torx security screwdriver set I cant find one that fits Sad
Anyone else had this problem. I'm close to going captain caveman on its ass and drilling all the bolts out:cursing:
12-04-2018, 11:33 AM #1
12-04-2018, 11:43 AM
/goes on the hunt.
I'm ashamed to say I've made a right pigs ear of my ECU wiring so I want the opportunity to put it right but I'll need to get the ruddy thing out first.
12-04-2018, 11:43 AM #2
/goes on the hunt.
12-04-2018, 11:55 AM
Gord I used a small punch to tap it round, pain in the bum, but works :thumbup1:
Whoosh..
You did what? Lol
I chizzled one of the center nipples out in an attempt to get an ordinary torx in there, but that didn't work for me either
12-04-2018, 11:55 AM #3
Whoosh..
You did what? Lol
12-04-2018, 11:57 AM
take a grinder and turn the fancy tamper proof bits in to slots for a normal screw driver
[Image: picture215n.jpg]
12-04-2018, 11:57 AM #4
12-04-2018, 11:58 AM
they are not normal tamper proof torxs bits they are 5 point not 6 thats why your bits wont fit.....
12-04-2018, 11:58 AM #5
12-04-2018, 12:03 PM
Right got it. As I haven't got a grinder (nearest thing is a poxy dremel) I guess my only alternative is to drill the mofo's out?
12-04-2018, 12:03 PM #6
Phil01
12-04-2018, 12:10 PM
Ive got a dremmel with cutting disc's and a small angle grinder, shout if you wanna borrow it Jim
Phil01
12-04-2018, 12:10 PM #7
12-04-2018, 12:13 PM
Cheers mate I might take you up on that. I'll have a go with what I've got here first and then if that fails you'll probably get a call from me crying down the phone.
12-04-2018, 12:13 PM #8
12-04-2018, 12:14 PM
a dremmel will do mate just make sure the disk is wide enough so when you do cut a groove the screw driver fits in..i wouldnt drill them..
12-04-2018, 12:14 PM #9
12-04-2018, 12:16 PM
ormi a dremmel will do mate just make sure the disk is wide enough so when you do cut a groove the screw driver fits in..i wouldnt drill them..
Ok dude. Are the bolts on the is200 countersunk btw?
12-04-2018, 12:16 PM #10
Replies 35
Views 1,611
02-11-2019, 12:11 PM
Views 552
28-10-2018, 03:56 AM
Views 333
21-04-2018, 12:21 PM
Last Post by Andy-R.
Views 506
06-10-2017, 09:00 AM
