JapCarForum Trade Area Trade Archive Wanted Archive supercharger help
supercharger help
supercharger help
dandydons
16-10-2017, 11:21 AM
Guys - I have having a nightmare - just after I decided to split the car up as in remove the charger and sell car separately .
Just back from a 80 mile return trip - and about a mile from home and very suddenly a loud whine and lack of power - cruised home and found the spring at supercharger has sheared off. Sounded like a belt was slipping.
So 2 questions :
1. Does anybody have a spare spring or know where to get one ?
2. Can anybody post up an idiots guide to removing the belt for the charger so at least I can run the car ?
Pics would be great please..
Thanks in advance.
I am sure I have read before the springs are weak but just typical to happen when I decide to sell the whole kit.
Cheers
kev
dandydons
16-10-2017, 11:21 AM #1
So 2 questions :
Thanks in advance.
Cheers
kev
16-10-2017, 11:23 AM
You wouldnt just be able to remove the belt and have it working mate, you will need an air supply, with no supercharger you arent getting an air supply are you?
16-10-2017, 11:23 AM #2
dandydons
16-10-2017, 11:50 AM
Dark Samurai You wouldnt just be able to remove the belt and have it working mate, you will need an air supply, with no supercharger you arent getting an air supply are you?
wasnt thinking about that.. so best bet is tripping the charger off completely and putting oriiginal airbox back on ?
If so can this be done by a novice like me -without ramps . I really need to have the car fit to use on Monday.
cheers
Kev
dandydons
16-10-2017, 11:50 AM #3
cheers
Kev
16-10-2017, 12:05 PM
Hi mate
You can probably get it stripped and back to standard in a few hours
when i stripped mine it took me about an hour and half once the bumper was off etc
if you need any help doing it give me a shout
Rabs
16-10-2017, 12:05 PM #4
Hi mate
Rabs
16-10-2017, 12:06 PM
You can just remove the belt, and disconnect throttle wire then the air goes through the bypass.
You need to loosen the tightener pully then the belt should just come off. You just need to loosen the bolt in the middle of the little pulley.
Then just unclip the throttle wire (move the wire so it comes out the slot)
As for the spring, what does it look like? a coil one or a round one like you get on pliers etc?
Its a known problem, when TTE were still going they would send you an uprated spring free, dunno what you could do now. but if you can find a similar spring it should work
16-10-2017, 12:06 PM #5
dandydons
16-10-2017, 12:08 PM
Rabster Hi mate
Rabs
Can you tell me what the steps are then Rabster ?
cheers Kev
dandydons
16-10-2017, 12:08 PM #6
Rabster Hi mate
Rabs
cheers Kev
16-10-2017, 12:22 PM
ummm
Disconnect Battery (not essential but good practice)
Remove bumper
undo SC pully remove belt and pulley replace cap on pully(taken of during inital install)
undo SC bolts
undo silicone hoses
remove SC from cradle
undo cradle (you will need to jack the Drivers side up to get the bottom bolt)
remove all SC piping and silicone hoses
Remove FMIC
Remove snorkel and replace bolts with standard ones from when fitting kit
remove TTE Airbox
remove Bypass cable from throttle
Refit standard Airbox
re fit bumper
Remove TTE Black box from ecu reconnecting wires
umm i think thats all steps any one else want to add to it lol
16-10-2017, 12:22 PM #7
ummm
Remove bumper
undo SC bolts
undo silicone hoses
Remove FMIC
remove TTE Airbox
re fit bumper
16-10-2017, 12:24 PM
Here are the fitting instructions: http://www.mediafire.com/?nwzzkkne22z
And the parts list: http://www.mediafire.com/?dgiayaoabac
They should help mate
16-10-2017, 12:24 PM #8
rob
16-10-2017, 12:25 PM
for a temporary fix, just remove the SC belt.
look at the tensioner - follow the belt down. 17mm spanner and loosen the bolt in the middle. remove belt and if you wish remve the tensioner.
refitting is just reverse process
rob
16-10-2017, 12:25 PM #9
dandydons
Sparkystav You can just remove the belt, and disconnect throttle wire then the air goes through the bypass.
Stav - that sounds like my best option for now. As for disconnecting the throttle wire - do you mean at the throttle side rather than the charger side ?
Think the spring is the original type not the second version that tte did . It looks to me there is a bit missing . will take some pics tomorrow in daylight and that might help .
dandydons
16-10-2017, 12:25 PM #10
Views 418
21-08-2019, 12:39 PM
Last Post by sprinter2012
Views 1,098
05-05-2019, 11:42 AM
Last Post by Ji123
Views 544
05-05-2019, 11:18 AM
Last Post by Jon
Replies 18
Views 1,095
15-04-2019, 02:56 PM
Views 424
10-02-2019, 01:22 PM
Replies 40
Views 2,023
16-05-2018, 07:26 AM
Last Post by Stoney
Views 580
29-01-2018, 01:52 AM
Last Post by fluff
