JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Help needed
Help needed
Help needed
thefridge
31-10-2017, 12:43 PM
Hi Guys,
I am going to go down the turbo route with my 1999 altezza. I have the turbo kit sourced but there is no ECU. I am no expert when it comes to this sort of stuff but would love to learn.
Can anyone recommend a good value for money ECU.?
Or does anyone have one for sale ?
Thanks
thefridge
31-10-2017, 12:43 PM #1
Hi Guys,
Thanks
31-10-2017, 12:50 PM
Greddy Emanage Ultimate is capable and reasonably priced, Apexi Power FC is a little more pricier but a good ecu.
And if your going all out the LINK G4 is unbeatable IMHO.
31-10-2017, 12:50 PM #2
31-10-2017, 12:55 PM
i will have my emanage blue up for sale in a months time. works good but if your going for big power and are going to run non toyota/denso injectors the you need the ultimate.
31-10-2017, 12:55 PM #3
thefridge
31-10-2017, 01:04 PM
ok thanks lads, How much will you be looking for yours. I am not looking for massive gains but was thinking about changing the injectors.
thefridge
31-10-2017, 01:04 PM #4
31-10-2017, 01:11 PM
as long as your running toyota denso ones under 450 cc then it's fine for that. but if you going to run power enterprize ones that are 550 cc or higher then it wont handle them.
they sell on ebay for 300 pounds without harness and boost map sensor and i have everything needed. harness and boost sensor for 200. the harness will need work but the plugs needed are there. harness costs 50 pounds and map sensor is another 40
31-10-2017, 01:11 PM #5
thefridge
31-10-2017, 01:32 PM
ok cheers. Is any emanage ultimate programmable to suit your car or are they made specificly for the car. As in can i but a new one that a guy had for a levin ??
Will the apexi hand controller work along with this?
Thanks again lads
thefridge
31-10-2017, 01:32 PM #6
Thanks again lads
31-10-2017, 01:40 PM
you can wipe the info from them and reprogram them to each car. i dont think the apexi will work but i might be wrong.
here mate is a list on ebay for you with prices.
http://shop.ebay.co.uk/i.html?LH_AvailTo...op=2&_sc=1
was a bit shocked to see the usb cable and suport cd was 80 pounds. wow.
hope it helps
31-10-2017, 01:40 PM #7
hope it helps
31-10-2017, 01:53 PM
How about a unichip
31-10-2017, 01:53 PM #8
How about a unichip
Replies 32
Views 2,669
17-03-2018, 01:16 AM
Views 612
18-01-2018, 06:44 PM
Last Post by liquidlazer
