JapCarForum Cars, Cars, Cars! Wheels & Tyres Alloy wheel fitment guide
mattlaw
02-11-2017, 01:41 PM
Is there 1 knocking about? I've had a look but can't find 1, will a 8x18 with et35 fit an is? Thinking of getting rid if both current sets and going for something completely different
mattlaw
02-11-2017, 01:41 PM #1
03-11-2017, 02:26 AM
et should be 45.
i run 8.5 20" et 42 without problems and i have not rolled my arches. i also have a 3mm spacer on just to get it right.
03-11-2017, 02:26 AM #2
et should be 45.
reganlives
03-11-2017, 03:20 AM
so whats the specs of the aero 18s then? I'm starting a lil project with my car n will be changing my wheels down the line to 18s but aint got a clue about what width/offset to go for
reganlives
03-11-2017, 03:20 AM #3
03-11-2017, 11:33 AM
yip gord is right im running et35 8x18 i have no arch work and mine is dropped 90mm front and 100mm rear but i am running a little camber on the rear and i have to use 215x40x18 tyres no chance of using 225's as their is no room.
03-11-2017, 11:33 AM #4
reganlives
04-11-2017, 03:38 AM
so if i wanted to fit 18s on mine but run 225s then what would i have to do? Bare in mind mine isnt lowered so think i'd be able to get away with the same spec wheels as u with wider tyres but i do also want room for improvement incase i lower it.
reganlives
04-11-2017, 03:38 AM #5
04-11-2017, 03:54 AM
i run 225 on 20" with et 45. 35mm drop and no rolled arches. get the right et and tyre size and you will have no problems
04-11-2017, 03:54 AM #6
spikes
04-11-2017, 11:06 AM
remember if you go for sizes gord has said there will be no probs, and if you wanted them out a bit more you could use spacers.
spikes
spikes
04-11-2017, 11:06 AM #7
spikes
reganlives
04-11-2017, 07:17 PM
thanks gord. So on an 8j rim what width tyre would i need? I'm defo going to be going wider than the standard 17" rims and i'm guessing aeros are the same width as the 17s?
reganlives
04-11-2017, 07:17 PM #8
reganlives
05-11-2017, 07:40 PM
right then looks like i'll be going for 8j rims then i think and possibly 235 tyres as they should fit with the car not being lowered anytime soon.
reganlives
05-11-2017, 07:40 PM #9
06-11-2017, 10:51 AM
^^^^^ no danger with a 235 with a et of 35 you will defo stick out past the arch!!
225 you might get away with as long as its only you and a front seat passenger and thats a might..
you might not have lowered your car but when you are carrying people and shopping the springs will compress so you will get rubbing the safest thing you can do is get the 215x40x18 tyre i am speaking from experiance if you want to go wider than a 215 scrap the et35 wheels....
06-11-2017, 10:51 AM #10
Views 400
01-03-2023, 07:03 AM
Views 630
15-03-2021, 05:14 AM
Last Post by Morango
Views 800
04-06-2020, 11:08 PM
Last Post by purplewitch
Views 642
17-05-2020, 12:17 PM
Last Post by Colin G
Views 799
24-12-2019, 09:51 AM
Views 2,879
11-08-2019, 04:16 AM
Views 1,443
29-06-2019, 10:52 PM
Last Post by Dinho
Views 1,262
25-06-2019, 07:38 AM
Last Post by Mr Reman
