JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security In Car Pc Touch screen Making
Pages (3): 1 2 3 Next
16-11-2018, 07:01 PM
ok so we now have another section of my project completed see details below, there are not alot of pictures of the production stage but mainly the finished article.
so anyway 1st things 1st i had to but another screen, after having a liliput screen in my nav housing which seemed to perform wonderfully i hunted for the smae model again.
liliput 619gl
i then attacked this to make it fit inside the standard IS200 Fascia adaptor alot of you are familiar with The walk through HERE
the same principal applies except i cut the existing screen housing apart to make it fit inside the hole
i then used Hurricane & plastic filler to smooth it all followed by primer and paint
So yeah umm here is the finished article in the car
[Image: 789411f0.jpg]
shortly after this i took the pc back out the car to do some work mainly software based but as its been slow due to weather lately
Main thing was to: -
install a Relay board Driver
Windows Updates
Adjust PSU boot times etc (carnetix PSU2410) adjusted by pc software
Customize background of software
attempt to fix satnav problem...
well out of all the above the Sat nav is still outstanding, don't think that's to bad considering lol
Lets start with the background this is done via a Hack in centrafuse once installed you can place pictures into the images directory and either have them rotate through each time it boost or lock it to a image.
i chose a pic of my car which has been customized
So here is before
[Image: 0eb8d67f.jpg]
pic after
[Image: 63e7f368.jpg]
so with this installed i then moved onto the Realy board, the whole reason for this is im running out of places to install switches lol , this particular board runs on USB with a 12v input and can switch 12v via relays so i have assigned 4 circuits to start with
Circuit 1 - Inter cooler
Circuit 2 - Strobe Lights
Circuit 3 - Front Camera
Circuit 4 - Audio Amps.
the software has been developed to work as a hack so once installed will automaticly install the relevant task area and buttons on the Centrafuse front End
[Image: 501e6926.jpg]
Labelled up circuits ok only 2 labelled but you get the idea
[Image: a6bb8100.jpg]
here is the board in test status on my Living room floor
[Image: bd4f8f2a.jpg]
as you can see LED2 is illuminated this means that the Relay is now in the Normally open position closing the circuit thus giving me a 12v output on that switch
when you press a button on the touch screen the button illuminates green to indicate its operation
[Image: 156a5c81.jpg]
the board can be set with 2 system
syetem one to allow toggle press (so it flashes the output upon being pressed non latching)
or
System two Latched output (a single press on the circuit will latch the output and stays latched until pressed again)
[Image: th_d398279c.jpg]
[Image: th_81eacf7b.jpg]
Hope you like what you see
Rabs
Edited 29-12-2010, 12:15 AM by Fozzy.
16-11-2018, 07:01 PM #1
liliput 619gl
Windows Updates
So here is before
pic after
or
Rabs
Chri5
16-11-2018, 07:16 PM
very nice indeed andrew Wink
i'd love to have the knowledge to be able to do that.
plus i'd be scared of damaging them and having to buy another screen lol
Chri5
16-11-2018, 07:16 PM #2
16-11-2018, 07:17 PM
Chri5 we can do one for you car if you want ill work out the bits you need and we can sort something out much better than a double din radio.
16-11-2018, 07:17 PM #3
Looks good mate, lot of work gone into it.
16-11-2018, 07:17 PM #4
16-11-2018, 07:21 PM
Oh meant to say i also installed a HD radio circuit in the car it still runs through old antenna but works a treat and has a custom cable thats been designed to work with the Front end Centrafuse kinda plug and play other than giving it power
the only thing to remember when doing anything radio wise on the IS200 is the antenna is a powered one and as such must be powered after removing standard radio same applies for many other cars and 90% of decent aftermarket radios have a Power antenna Output
16-11-2018, 07:21 PM #5
Chri5
16-11-2018, 07:22 PM
Rabster Chri5 we can do one for you car if you want ill work out the bits you need and we can sort something out much better than a double din radio.
yes plz mate Wink
so what else can you get this to do???
Chri5
16-11-2018, 07:22 PM #6
yes plz mate Wink
16-11-2018, 07:25 PM
wow man you must never sleep and if you do is this were you dream up all this stuf to put in the car. might just put in a satalite dish and be done with it. :lol:
16-11-2018, 07:25 PM #7
16-11-2018, 07:26 PM
you tell me what you want it to do and we can go from there you can run a total of 36 relays together on this program
so im thinking i may change my heated seats to a switch on the PC possibly wire a vent circuit in that's 3 switches taken ummm lol im liking the idea of an ejector seat as it goes....
16-11-2018, 07:26 PM #8
Chri5
16-11-2018, 07:27 PM
jay_russell wow man you must never sleep and if you do is this were you dream up all this stuf to put in the car. might just put in a satalite dish and be done with it. :lol:
sleep is for wimps lol :w00t:
just bring on plenty of coffee and proplus
Chri5
16-11-2018, 07:27 PM #9
funny you should say that i was looking at a decent Pc based Freesat system ... but the dish its very aerodynamic :whistling:
16-11-2018, 07:27 PM #10
Views 2,281
28-04-2019, 04:31 PM
Last Post by jasons
Views 2,610
15-03-2018, 10:34 AM
Last Post by Asi
Replies 51
Views 6,704
27-01-2018, 09:14 AM
