JapCarForum Cars, Cars, Cars! General Car Maintenance possible ball joint or not?
widnes_is200
24-11-2018, 03:44 PM
hi folks, im having a horrid noise coming from my frount wheel like a rubber sqweek grinding noise, first noticed it on steering , sounded a bit like low steering fluid, but now it it on bumps when strait and at its worse when steering , does anybody know if the ball joint makes this noise when going, as i know there not easy to detect on a is play wise, also is it likely to be the bottom , cheers
widnes_is200
24-11-2018, 03:44 PM #1
widnes_is200
25-11-2018, 04:06 PM
bumpity bump anybody
widnes_is200
25-11-2018, 04:06 PM #2
TommyH
26-11-2018, 11:17 AM
Hi Dave, i had the same symptoms/noises and it turned out to be the bottom ball joint mate, and remember to get your geomtry done after replacing ball joints.
TommyH
26-11-2018, 11:17 AM #3
widnes_is200
26-11-2018, 06:01 PM
cheers tommy i thought so, changing it in the morning then ille wizz down to work and check the tracking, not a nice noise is it,
widnes_is200
26-11-2018, 06:01 PM #4
Views 2,959
05-03-2022, 03:22 PM
Last Post by kevinsgs300
Views 1,086
11-03-2021, 11:58 AM
Views 1,035
03-01-2020, 05:46 PM
Views 1,480
25-03-2019, 02:25 PM
Last Post by D6NGR..
