JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Any issues with removing this? (headlight bar)
24-12-2017, 02:44 AM
I want to remove these bars so that I can rub them down and give them a bit of a respray. Should I be aware of anything that might fall apart if I unbolt them?
[Image: l_untitled_1.jpg]
24-12-2017, 02:44 AM #1
24-12-2017, 03:17 AM
i shouldnt think so, wouldnt drive anywhere without them though just in case
24-12-2017, 03:17 AM #2
24-12-2017, 03:19 AM
Sparkystav i shouldnt think so, wouldnt drive anywhere without them though just in case
Cool. Nah not planning on using the car with them removed. Just wanted to make sure that when I undo the bolts, the headlamps dont fall out or something pings out of place and is impossible to fit back in :p
24-12-2017, 03:19 AM #3
Fry-Up
24-12-2017, 09:54 AM
are they removable, I thought they were welded at the wing end?
Fry-Up
24-12-2017, 09:54 AM #4
24-12-2017, 09:55 AM
Fry-Up are they removable, I thought they were welded at the wing end?
No idea tbh. There is a bolt that joins them to the wing, but I suppose there could be a weld too?
24-12-2017, 09:55 AM #5
Fry-Up
24-12-2017, 10:07 AM
I need to have a proper look at mine anyway as they are still slightly bent from late last year and still need pulling straight, but i'm sure I saw a weld
Fry-Up
24-12-2017, 10:07 AM #6
Mikey
24-12-2017, 01:13 PM
think they are welded in where it joins the wing
Mikey
24-12-2017, 01:13 PM #7
nuts Sad
24-12-2017, 01:13 PM #8
nuts Sad
Views 461
30-10-2019, 05:26 AM
Views 810
19-01-2019, 10:29 AM
Replies 18
Views 1,254
23-08-2018, 12:29 AM
Last Post by northernmonkey
