JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission TRD Diff??
TRD Diff??
TRD Diff??
10-01-2018, 11:38 PM
hi there,
just a quick question would the altezza diff fit the is200 prop? also how would the TRD 2 way diff compare to a kaaz one any idea?
10-01-2018, 11:38 PM #1
hi there,
11-01-2018, 06:31 AM
IS200 and Altezza diff are interchangeable. The only differance is the drive shaft bolt patterns, but they are swapable anyway so thats not an issue - the Altezza diff housing has moulded cooling vents also.
11-01-2018, 06:31 AM #2
11-01-2018, 09:28 AM
right thats great mate.
11-01-2018, 09:28 AM #3
Talisker
11-01-2018, 09:49 AM
I thought I read somewhere the ratios are slightly different. Or am I thinking of the IS300?
Talisker
11-01-2018, 09:49 AM #4
11-01-2018, 10:07 AM
The auto has a silly ratio, and the RS200 has that ratio also, however its easy to swap the ratios also.
11-01-2018, 10:07 AM #5
11-01-2018, 10:14 AM
well for the v8 it would entirely different i need the diff ration to be as close to the supra diff as im running a r154 gearbox
11-01-2018, 10:14 AM #6
11-01-2018, 10:23 AM
The TRD one is just the auto ratio - nothing more so is fast acceleration, revs easier but at the loss of top end speed and more fuel usage (not that it matters for the V8)
11-01-2018, 10:23 AM #7
12-01-2018, 01:52 AM
thanks for the help mate
12-01-2018, 01:52 AM #8
12-01-2018, 01:54 AM
The TRD diff was in the IS200 i used to have, with a normal diff it was far better.
12-01-2018, 01:54 AM #9
12-01-2018, 07:19 AM
right i see thanks for the info mate. helps a lot just going to stick with what i have
12-01-2018, 07:19 AM #10
Views 290
17-11-2021, 04:45 PM
Last Post by adamhsn
Views 237
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 279
29-08-2020, 11:41 AM
Last Post by Connor376
Replies 23
Views 939
17-05-2019, 05:38 AM
Last Post by Ji123
Views 1,123
01-09-2018, 11:46 AM
Last Post by Bonney
Views 223
27-12-2017, 12:22 PM
Last Post by LEX11S
Views 979
30-04-2017, 03:02 AM
Views 433
03-06-2016, 12:48 PM
