JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension handbrake light stays on
Pages (3): 1 2 3 Next
14-02-2018, 12:12 PM
Ok people with all the knowledge , My handbrake light stays on all the time, but saying that after a drive and if you switch of the engine then put it back on again sometimes it will go off. But as soon as you put the handbrake back on the light will stay on again.
What will I need to do to get this annoying light to stay off ??
14-02-2018, 12:12 PM #1
14-02-2018, 12:13 PM
check the brake fluid also check the brake lights....
14-02-2018, 12:13 PM #2
14-02-2018, 12:14 PM
take the lamp out :Chair:
14-02-2018, 12:14 PM #3
Fry-Up
14-02-2018, 12:16 PM
it'll just be a brake bulb
Fry-Up
14-02-2018, 12:16 PM #4
14-02-2018, 12:21 PM
Ok never thought it would be a brake bulb out , that would cause the handbrake light to stay on.
I just checked and I have a blown brake bulb.
Mrs Moley had the car today and see was worried sick driving it with the light on the dash.
Just away to change the bulb and see if that sorts it .
Thanks guys !!
14-02-2018, 12:21 PM #5
Thanks guys !!
Fry-Up
14-02-2018, 12:29 PM
when I had pulsing brakes I didn't fit load resistors and the handbrake light was always on, s'the only reason I know its generally just a bulb out
Fry-Up
14-02-2018, 12:29 PM #6
Phil01
14-02-2018, 12:33 PM
Dean the red light is not just a handbrake light it is also a lamp failure warning and a low brake fluid level warning
Phil01
14-02-2018, 12:33 PM #7
14-02-2018, 12:34 PM
nopebrake light bulb out hand brake light stays on, fluid low hand brake light on...... rear light bulb out then you get the amber warning light
14-02-2018, 12:34 PM #8
14-02-2018, 01:04 PM
Well changed the bulb and the handbrake / warning light is now sorted.
Happy Moley again !!
Thanks for the help guys
14-02-2018, 01:04 PM #9
14-02-2018, 01:22 PM
is it different on the 200's then as on the 300 we have a light of it own for faulty brake lights
14-02-2018, 01:22 PM #10
