JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Fog Light Connection
TommyH
26-02-2018, 09:49 AM
Hi folks. I'm looking for some advise. I got myself a secondhand pair of front fogs but didn't realise the fog connectors changed from 2000 to 2001 onwards Blush
My question is has anyone got any advise on how i could make the newer 2003 connectors fit in my older 2000 connector ?
Cheers.
TommyH
26-02-2018, 09:49 AM #1
Cheers.
26-02-2018, 10:09 AM
you could upgrade your fogs to HID's and then wire direct to the ballast thus avoiding the connector problem....
alternatively if you can find the connectors you could cut and solder new ones on...
26-02-2018, 10:09 AM #2
TommyH
26-02-2018, 12:06 PM
Thanks for the advise Rabster. I think trying to find the newer wire is a cheaper option. Hopefully i can source one.
Does anyone know for sure, when the connectors for the front fogs changed.
I THINK it maybe 2001 onwards but not 100% certain.
TommyH
26-02-2018, 12:06 PM #3
26-02-2018, 12:16 PM
pretty sure it was 2003 mate, as that's what they list on a few sites for the bulbs??
26-02-2018, 12:16 PM #4
TommyH
26-02-2018, 12:19 PM
Bandit pretty sure it was 2003 mate, as that's what they list on a few sites for the bulbs??
Thanks for that mate :thumbup1:
TommyH
26-02-2018, 12:19 PM #5
TommyH
26-02-2018, 01:08 PM
Do you think this is what im looking for http://cgi.ebay.co.uk/2001-2002-LEXUS-IS...20b7284b1f
TommyH
26-02-2018, 01:08 PM #6
TommyH
27-02-2018, 04:43 AM
Rabster you could upgrade your fogs to HID's and then wire direct to the ballast thus avoiding the connector problem....
So Rabster, if i went for the HID route, would i order an H3 kit (new fogs) and wouldn't need to cut any wires on my HB4 connectors. Would this be just plug and play ?
Thanks
TommyH
27-02-2018, 04:43 AM #7
Thanks
01-03-2018, 01:05 AM
Shahz has fitted the newer ones on his car, worth asking him how difficult it was to do.
01-03-2018, 01:05 AM #8
TommyH
01-03-2018, 01:10 AM
Thanks Parthiban but iv'e booked it into a garage tomorrow to get it done.
Electric's are not one of my stronger points Confusedad:
TommyH
01-03-2018, 01:10 AM #9
01-03-2018, 01:26 AM
Ok cool, he mentioned it on the thread when I was asking about replacing a fog light (which I still haven't got round to doing :blushingSmile and I think it was just a case of cutting off the old connectors and soldering the new ones one but if it's at a garage they should be able to figure it out Smile
01-03-2018, 01:26 AM #10
Views 470
06-10-2019, 10:59 AM
Last Post by jomo
Views 544
04-04-2018, 07:24 AM
Last Post by jasons
Views 539
27-12-2017, 01:15 PM
Last Post by PINGU
Replies 24
Views 1,211
16-01-2017, 03:02 PM
Last Post by Chri5
