JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Interior light help needed
davidjamesbattersby
03-10-2018, 08:12 AM
Can any one tell me which wires are the negative. Perm live and the switched live wires are in the roof light please
davidjamesbattersby
03-10-2018, 08:12 AM #1
davidjamesbattersby
03-10-2018, 08:13 AM
Sorry it's a 1999 is 200
davidjamesbattersby
03-10-2018, 08:13 AM #2
davidjamesbattersby
03-10-2018, 09:46 AM
bump please can any one help, just looked at a wiring diagram but still cant figure out what wires are for what
davidjamesbattersby
03-10-2018, 09:46 AM #3
03-10-2018, 10:13 AM
Do you have a multi meter??? Or take a look at the switch the live is always the switched side - earth's are never usually switched for safety reasons.
Edited 14-11-2011, 08:02 PM by FirebirdPhil.
03-10-2018, 10:13 AM #4
Just-Phil
03-10-2018, 10:17 AM
Found this, really not sure if it helps at all?
Right i've searched through my old paperwork and found my diagrams for when i wired up my Roof screens interior light.
There should be 5 wires going into the light:
Red & White
Black & White
Blue & Yellow
Green with Silver Flecks
Green Orange.
The ultrasonic sensor should then plug in the other side. Take that plug out and unscrew the sensor and fit it somewhere in the roof or screen holder.
The connections should then be as follows:
Red & White - Light on with Door open
Black & White - Light on Permantly
Blue & Yellow - Bulb and last wire on sensor
Green with Silver Flecks - Red wire from sensor
Green Orange - Blue wire from sensor.
Just-Phil
03-10-2018, 10:17 AM #5
Red & White
Black & White
Blue & Yellow
Green Orange.
davidjamesbattersby
03-10-2018, 11:10 AM
thats great whast the earth then lol and whats the sensor attached to it
davidjamesbattersby
03-10-2018, 11:10 AM #6
davidjamesbattersby
03-10-2018, 12:01 PM
any idea where i can pick up a earth for this then im sorted
davidjamesbattersby
03-10-2018, 12:01 PM #7
03-10-2018, 01:08 PM
which light you on about?
the roof light that turns on with the door?
then there is no earth wire. The "on" selection goes directly to earth.
the red wire goes to the ECU
the blue/yellow wire goes to the live
03-10-2018, 01:08 PM #8
davidjamesbattersby
03-10-2018, 01:13 PM
im fittim bmw lights in the c pillor so need a live that is from when the door opens, a live thats switched(ideally) or permanent and a earth for them
davidjamesbattersby
03-10-2018, 01:13 PM #9
davidjamesbattersby
03-10-2018, 01:26 PM
stav is the info above from just phil correct, if so all i need to do is pick up a earth from some where near the rear c pillor
davidjamesbattersby
03-10-2018, 01:26 PM #10
Views 470
06-10-2019, 10:59 AM
Last Post by jomo
Views 544
04-04-2018, 07:24 AM
Last Post by jasons
Views 764
01-03-2018, 03:24 AM
Last Post by TommyH
Views 539
27-12-2017, 01:15 PM
Last Post by PINGU
Replies 24
Views 1,211
16-01-2017, 03:02 PM
Last Post by Chri5
Views 405
27-10-2016, 02:07 PM
Views 794
25-05-2016, 04:08 AM
Last Post by Andy-R.
