JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission 1GFE Flywheel information
05-03-2018, 12:07 PM
Does anyone know the PCD of the 1GFE flywheel?
05-03-2018, 12:07 PM #1
LEX11S
08-04-2018, 11:32 AM
no but i have two spare flywheels sat here if you tell me how to do it
LEX11S
08-04-2018, 11:32 AM #2
24-05-2018, 12:23 AM
For anyone who would like to know, the Lexus IS200 OEM flywheel PCD is 264mm
24-05-2018, 12:23 AM #3
XeDoX
21-06-2023, 09:22 PM
Isn't 264 a little too much ? Can someone measure the PCD again , I need to check something,I think I have found easy replacement for solid flywheel.
XeDoX
21-06-2023, 09:22 PM #4
21-06-2023, 11:43 PM
Nope 264mm is correct for the clutch cover PCD.
As you after the PCD of the bolts to the crank instead?
21-06-2023, 11:43 PM #5
XeDoX
22-06-2023, 12:14 AM
Yes ,sorry. I was looking for the crank bolt pattern pcd.
XeDoX
22-06-2023, 12:14 AM #6
Views 293
11-02-2021, 12:16 PM
Replies 18
Views 887
20-08-2020, 08:52 AM
Views 393
03-07-2020, 11:00 AM
Last Post by mattlaw
Views 610
21-09-2019, 11:40 AM
Views 935
30-01-2018, 01:07 PM
Last Post by danielson
Replies 29
Views 1,788
10-09-2017, 07:50 AM
