JapCarForum Car Manufacturers Lexus/Toyota Black Pearl Emblems
Black Pearl Emblems
Black Pearl Emblems
Cous3
14-03-2018, 02:57 AM
I finally got the time to change the rear emblems over to the Black Pearl ones that I had bought a few weeks back.
WD-40 and fishing line was all that was needed to remove them, give them 5 mins to soak up the WD-40 and then just work the fishing line (or dental floss) behind the badges in a kind of sawing motion. Note* There are pins on the emblems so you obviously need to know where they are by refering to the new emblems.
Before starting ensure you do the following: The "Lexus"word emblem and the "L" emblem have pins and so it's easy to relocate the new emblems back in the correct place. However the "IS 250" emblem is all seperate numbers/letters with only the "S" and the "0" having pins. The way around this is to use masking tape directly below the whole emblem and mark on the tape where each number/letter sits. I also used masking tape at the sides of the first and last letter/number so ensure they were straight.
Once removed a quick rub with your thimb nail removes the remaining sticky foam and then a little Tar Remover takes off whats left. I then cleaned the areas with Meths to make sure it was clean of any grease etc.
Then it's just a case of taking your time and reapplying the nice new emblems, stand back and admire your work:thumbup1:
[Image: 396416981.jpg]
[Image: 396416983.jpg]
[Image: 396416982.jpg]
I've not added the carbon inserts to the "L" emblem yet as I have to the front grill.
Keith
[Image: 396337444.jpg]
Cous3
14-03-2018, 02:57 AM #1
Keith
14-03-2018, 03:01 AM
looking good mate
14-03-2018, 03:01 AM #2
looking good mate
14-03-2018, 03:05 AM
looks good :thumbup:
14-03-2018, 03:05 AM #3
Views 494
03-02-2023, 07:50 AM
Last Post by theblitz6666
Views 571
20-04-2021, 10:48 AM
Last Post by Alpine89
Replies 27
Views 1,854
26-05-2018, 06:03 AM
Last Post by Cous3
