JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza What am I missing from a 60k service...
16-03-2018, 11:56 PM
I'm gonna soon be ticking over to the 60k mark, but tbh I think that a lot of what would be in a normal 60k has already been done at 52k. So whats left apart from below...
- Timing belt done at 52k
- Water pump done at 52k
- Oil, Trans fluid, coolant done at 52k
- Oil filter done at 52k
- Sparks done at 52k (but will be putting colder ones in when SC comes anyway)
I spoke to my local Lexus dealer and told them that the above had already been done, but they still quoted me £500 for a 60k service which sounds like loblocks.
I cant think of anything that would make the service cost that much?
16-03-2018, 11:56 PM #1
17-03-2018, 12:16 AM
Jim stick your car into Westfield motors in Rayleigh there number is 01268-783205 Ian & Chris the owners there will look after your car and can loan you a car while yours is in for less than a tenner
Also you wanted to get your windows tinted you could Go to Terry that done mine his number is 07961542533 he just outside Wickford
17-03-2018, 12:16 AM #2
17-03-2018, 12:20 AM
Jim which stealership was that ?
try calling Woodford toyota see what there price comes in at might be able to get it cheaper there
17-03-2018, 12:20 AM #3
17-03-2018, 01:01 AM
Lexusboy Jim stick your car into Westfield motors in Rayleigh there number is 01268-783205 Ian & Chris the owners there will look after your car and can loan you a car while yours is in for less than a tenner
Cheers mate I'll give them both a call. I'm in two minds about getting my side windows tinted but I definitely want a sun strip on the windscreen to make it look a bit more aggressive if your guy can do that.
Rabster Jim which stealership was that ?
Was one on the way to Southend IIRC? TBH I thought that it had gone, but maybe not.
17-03-2018, 01:01 AM #4
17-03-2018, 01:18 AM
Gord If that was my car, i would be having oil & filter change Jim, would poss have air filter, but i think you not running standard air filter ?
Ah yeah that's a point. I also told them that I wouldn't be needing those done either (because of the Injen).
I was contemplating doing the oil myself, though the removal of the filter on the IS300 looks like a biznatch to do? I'd quite like to run some Amsoil in there with maybe a TRD filter and get one of those magnetic sump plugs?
17-03-2018, 01:18 AM #5
17-03-2018, 01:24 AM
Gord Don't bother with TRD filter mate, the standard one is just as good, try having a look on LOC, monster prat posted something up years ago now, someone cut both the filters in 1/2 and did tests and i'm sure the standard Toyota filter came out best Big Grin
Good call mate. TBH the only reason I wanted it was because its red lol.
Maybe I'll just paint the Toyota one :p
17-03-2018, 01:24 AM #6
17-03-2018, 01:29 AM
Yeah, TRD filters aren't worth it! Just spraypaint TRD onto your Toyota one :lol: Edit: Bah you beat me to it!
Your list looks pretty comprehensive. I take it it hasn't had the oil pump replaced (not that you would at 60k, it just seems the only thing missing on the list)?
Toyota's services can be pretty mad, if they stick to the guide then it will involve inspecting a lot of parts and replacing them if required, like vac hoses, aux belts, brake and fuel lines, checking tightness of important bolts etc etc
17-03-2018, 01:29 AM #7
17-03-2018, 02:01 AM
toxo Yeah, TRD filters aren't worth it! Just spraypaint TRD onto your Toyota one :lol: Edit: Bah you beat me to it!
I don't think the oil pump has been replaced, but tbh I've only got the checklist from the last service (the 52k one) and it's not mentioned on there. I doubt it would have been done any earlier than that though, as you say.
I would quite like the Lex stamp for the 60k, but I'm wondering if its really worth it Confused
17-03-2018, 02:01 AM #8
17-03-2018, 02:03 AM
i used to think that must get the stamp for the main service points but then realised i was throwing money away on stuff that i can do or if i cant i know some one who can lol
17-03-2018, 02:03 AM #9
17-03-2018, 02:07 AM
Jim the Lexus Dealer in Southend is still around mate they have moved the servicing to Rayleigh Weir it is down past the Sainsbury Store and head towards Dansk.
17-03-2018, 02:07 AM #10
Views 845
01-08-2018, 10:35 AM
Views 223
28-07-2018, 06:18 AM
Last Post by jasons
Views 332
19-07-2018, 02:53 PM
Last Post by ormi
Views 259
09-04-2018, 06:21 AM
Last Post by karlp
Views 837
04-04-2018, 12:47 AM
Last Post by jasons
Views 666
29-03-2018, 01:21 PM
Last Post by Fry-Up
Views 236
15-10-2017, 04:41 AM
Views 538
11-06-2017, 09:01 AM
Views 447
20-05-2017, 04:27 AM
