JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Poor Radio Reception
jasons
23-03-2018, 10:44 AM
Is this a common fault on the IS??
If I search it doesnt pick up any stations, but when I set it to TA it picks up the station broadcoasting the traffic info ok..
Any thoughts?
Cheers,
J
jasons
23-03-2018, 10:44 AM #1
Any thoughts?
Cheers,
J
23-03-2018, 10:47 AM
Might not be the same issue, but whenever I search for new stations in my IS, I always have to go round the entire frequency range twice.
First time it picks up nothing, second time it picks up all the stations.
Strange, but true.
23-03-2018, 10:47 AM #2
Strange, but true.
are you using factory or aftermarket radio
23-03-2018, 10:47 AM #3
jasons
23-03-2018, 10:56 AM
Factory, with (touch wood) no ERR codes...
jasons
23-03-2018, 10:56 AM #4
24-03-2018, 01:12 AM
Mine doesn't have any problems, but of course it could be area dependent.
Is there a way to measure the strength of the signal coming from the antenna?
24-03-2018, 01:12 AM #5
24-03-2018, 01:15 AM
It's a powered amplified antenna, could be there's an issue with the signal amp. I think that's why Rabs was asking if it were aftermarket because you have to make sure you retain power to the aerial amp when you change!
24-03-2018, 01:15 AM #6
lex2oos
24-03-2018, 08:27 AM
I have aftermarket unit. And radio reception is poo... there is power to the amp, and once disconnected it gets even worse...
lex2oos
24-03-2018, 08:27 AM #7
24-03-2018, 08:38 AM
Lex200s you have to run a feed to the amplified antenna from behind the head unit or you wont pick up a signal . its a set of wires directly behind the headunit and once i did it i got almost all the stations dependant on area of course
cant remember who gave me details on this will have a look
24-03-2018, 08:38 AM #8
Jimbob-T-Lex
Moderator
1,674
24-03-2018, 09:34 AM
I could do with the answer to this as ive installed after market and cannot pick up any stations now!!
Jimbob-T-Lex
24-03-2018, 09:34 AM #9
24-03-2018, 10:19 AM
http://www.outlawjapclub.co.uk/forum/sho...php?t=6307
this is the thread on it about halfway down the first page is the answer to ur question
24-03-2018, 10:19 AM #10
Views 366
28-12-2018, 10:07 PM
Last Post by jasons
