JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza IS Radio Mute Wire
IS Radio Mute Wire
IS Radio Mute Wire
jasons
28-12-2018, 11:42 AM
Hi all,
question as above- I have a bluetooth sat nav built in, but I want to add/use a standalone one.
Can anyone tell me if / what the colour of the wire for the radio mute is?
(I've had a search here, and over the other one and wanted a definative answer).
Thanks.
J
jasons
28-12-2018, 11:42 AM #1
Hi all,
Thanks.
J
28-12-2018, 12:20 PM
It's a red wire with white stripe.
But it's on the amp loom to the standard satnav not the stereo itself.
If you don't have standard satnav it annoy be there. But it's wire 13 in the same plug as the speaker wires.
28-12-2018, 12:20 PM #2
jasons
28-12-2018, 01:18 PM
Sparkystav It's a red wire with white stripe.
Cheers fella, not quite sure I understand, its not standard satnav, its a Sony unit in housing- so is it the wire on the stereo?
Cheers,
J
jasons
28-12-2018, 01:18 PM #3
Cheers,
J
28-12-2018, 01:24 PM
Right, did you have standard satnav before?
If not be wire may not be in the plug.
But if you look on the plug to the amp that the speakers wires are in (the same plug you attach to the amp bypass lead) there will be a gap. Thisis where that wire should be so fit one into the plug and it would work as a mute wire.
28-12-2018, 01:24 PM #4
jasons
28-12-2018, 01:37 PM
Cheers bud, sort of understand!!
Never had factory fit nav, but fitted a sony unit in a housing..
Was stated on LOC its straight out of he multiplug on the radio that it is:
Pin Number - Colour (Solid/strip/bar) - function
•1 - No connection
•2 - white/none//silver x2
•3 - green/none/silver x 2
•4 - blue/orange/sliver (but may look green/brown/silver) - MUTE
•5 - No connection
•6 - red/blue/silver x 2
•7 - No connection
•8 - blue/white/silver
•9 - green/none/silver
•10 - blue/yellow/silver - Const +12V
•11 - grey/white/silver - Acc +12V
•12 - green/white/none
jasons
28-12-2018, 01:37 PM #5
•1 - No connection
•5 - No connection
•7 - No connection
28-12-2018, 02:18 PM
I'm a bit confused. Do you still have the standard stereo?
The wire your after is from the amp by the glovebox
28-12-2018, 02:18 PM #6
jasons
28-12-2018, 10:07 PM
Standard stereo, so wire by the amp?
Good!!
Cheers,
J
jasons
28-12-2018, 10:07 PM #7
Good!!
Cheers,
J
Views 528
23-07-2018, 11:55 PM
Views 977
25-03-2018, 07:05 AM
Last Post by lex2oos
Views 497
06-10-2017, 04:56 AM
Last Post by jimxms
Views 419
24-10-2016, 01:47 AM
