JapCarForum Cars, Cars, Cars! Car Care & Detailing How do you clean your engine bay?
16-05-2019, 10:40 AM
The first time I cleaned my engine bay I did it like this:
- Run engine for a few minutes to heat it up.
- Covered over any electrical connectors and other bits I didnt think should get wet with cling film.
- Sprayed everything with Autoglym Engine Degreaser
- Left for a minute or two
- Used jet washer to wash it all off. Trying my best to avoid any electricals
- Left car for 30 mins to drip dry.
- Started engine to burn off anything left behind (lots of water in headers!)
Does that sound about right, or would you have done anything any differently? I'm planning to clean the engine again int he next few days.
16-05-2019, 10:40 AM #1
Dare
16-05-2019, 10:56 AM
I guess it depends how clean you keep your bay. Mine was covered in gunk and crusty dirt so I used the same method as you, bar the warming up.
Removed battery, avoided electrical connections, covered the bay in Auto Glym Engine & Machine cleaner, then lightly flowed water over the entire bay and left to dry.
Only this was my first attempt and i'd left the AG stuff on too long before rinsing which left me with some white chalky areas Sad
If yours is kept very clean then I reckon you should start thinking about polishes/wax to keep it more protected from dirt. From that point on you should just have torinse and top up on the polish every so often i suppose.
Dare
16-05-2019, 10:56 AM #2
16-05-2019, 10:59 AM
There are these two Polish blokes down the end of the road, and they will get it all gleaming for £10. It takes them about an hour and I have no idea how they do it!
16-05-2019, 10:59 AM #3
16-05-2019, 11:22 AM
I'm wondering if a steam cleaner is a better option than jet washing? I'd imagine you could be a little bit more blase about ti considering most of the steam would evaporate shortly after?
16-05-2019, 11:22 AM #4
16-05-2019, 11:57 AM
I do not have a jet wash/pressure washer, but I do have a steam cleaner. It's a £200 Karcher, not some cheapy job. It would be good for some of the finer detail, but it does take a long time to cover any area, so I would suggest maybe a steam after you have done the other method, just to get the details you have missed, if you want to get it stupidly clean.
16-05-2019, 11:57 AM #5
fluff
16-05-2019, 12:35 PM
Cleaning my engine is easy. Don't take the engine cover off then you don't have to see the dirtiness underneath.
fluff
16-05-2019, 12:35 PM #6
16-05-2019, 12:37 PM
That's the 'good' thing about most modern cars. Engine is well hidden away and just a few colour coded filler caps.
16-05-2019, 12:37 PM #7
16-05-2019, 12:39 PM
How's that a good thing! You end up with engine bays like this...
http://cache.jalopnik.com/assets/images/...cf8b_o.jpg
Can't see the important gubbins for the wires! It just makes the car manufacturers lazy...
16-05-2019, 12:39 PM #8
16-05-2019, 12:48 PM
Maybe more efficient engine designs don't lend themselves well to neatness? More direct routes, shorter wires and pipes = more efficiency?
Clutching at straws!
Personally though I'd rather see plastic covers than what 99% of engines look like.
16-05-2019, 12:48 PM #9
16-05-2019, 12:50 PM
Dunno Toxo - I look at that and think - "looks fast" :biggrin:
Might be a 1.0 Micra for all I know
16-05-2019, 12:50 PM #10
Replies 18
Views 3,510
13-01-2021, 01:49 PM
Views 2,083
15-06-2020, 04:52 PM
Last Post by Bandit
Views 1,153
15-02-2020, 01:20 PM
Last Post by jomo
Views 3,083
14-12-2019, 03:36 PM
Replies 22
Views 3,856
02-06-2019, 05:12 PM
Last Post by Bandit
Replies 27
Views 3,575
04-03-2018, 04:34 PM
Last Post by Asi
Views 2,409
21-01-2018, 09:57 PM
Views 2,500
18-05-2017, 07:59 PM
Last Post by Bandit
