Cold Air Intake Scoop From IS300...
As the title says, I'm after the OEM air intake scoop from an IS300, along with the air box cover (the bit that attaches directly to the scoop)
jimxms Man there's a big market for these. I've been asked like 4 or 5 times now for mine :p
Sell mine for....£200 :p
Dark Samurai Nobody takes them, gives a cold air feed to the filter
I've now located an air scoop so mods can remove this.
And I had wondered if that would happen Jim...I may look into making something like the SRT heat shield, which has a sort of flap over the outlet so you still get the airflow, but it just stops all the **** flying directly into your filter
