JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 120k service completed
kam05
22-06-2016, 11:37 PM
I did a 120k/12 year service on my IS200 on Sunday (as it was a sunny/rain free day I thought why not!).
I replaced the following items:
1. Coolant
2. Oil filter (with new sump nut/draining nut gasket)
3. Pollen filter
4. Gulf XLE fully synthetic 5w-30 engine oil
I won a OEM service kit from ebay 2 weeks ago (the service kit contained: oil filter (with draining nut gasket), pollen filter, air filter, spark plugs, air con cleaning spray (kills off bad smells from the air con/heating system). I used all of the items from this service kit apart from the air filter (I have a K&N filter, so I will keep the one supplied as a spare for when I clean/charge the K&N one) and I also didn't use the spark plugs (as I fitted a new set 20k ago, so these ones will be used later on). Lexus Leeds supplied my coolant and Opie oils supplied my engine oil.
Some pictures below of the air con cleaning spray:
[Image: DSC00188.jpg]
You spray the air con spray down the air vents for 5 seconds and leave to settle for 1/2 hour. Doing this kills bateria and bad smells. It leaves a nice cherry smell.
[Image: DSC00189.jpg]
[Image: DSC00190.jpg]
I'd recommend buying the air con cleaning spray from Lexus/Toyota if your air con/heating system smells.
I also cleaned my engine bay (I didn't take a before picture, but here is a after picture:
[Image: DSC00191.jpg]
I want to get my diff oil, gearbox oil and brake fluid replaced at some point (I can't remember when these were last changed). As I am not confident changing these oils/fluids can anyone tell me how much Lexus or a non-Lexus garage would charge me to replace these oils/fluids?
Kam
kam05
22-06-2016, 11:37 PM #1
1. Coolant
3. Pollen filter
Kam
22-06-2016, 11:46 PM
Looking good mate.
Have you charged your air con lately, i think it should be recharged every two to three years and run for a least a half hour each month.
Not sure on the price of the oil change, it only a phone call away though.
22-06-2016, 11:46 PM #2
Looking good mate.
22-06-2016, 11:47 PM
Engine bay looking great ! :biggrin:
Sorry, no idea about a price to change those fluids. Changing the diff oil and gearbox oil isn't a big job if you've got the car on the ramp, just a matter of taking out the drain plugs, letting the oil come out, then refilling through another plug.
Brake fluid change is slightly more involved because of bleeding the system but again it's not really a big job.
22-06-2016, 11:47 PM #3
kam05
23-06-2016, 01:10 AM
I don't have a ramp (just axle stands), so I want to get the diff/gearbox oils and brake fluid changed by a garage.
kam05
23-06-2016, 01:10 AM #4
Views 1,005
01-08-2018, 10:35 AM
Views 246
28-07-2018, 06:18 AM
Last Post by jasons
Views 378
19-07-2018, 02:53 PM
Last Post by ormi
Views 781
29-03-2018, 01:21 PM
Last Post by Fry-Up
Views 750
17-03-2018, 02:07 AM
Views 268
15-10-2017, 04:41 AM
Views 602
11-06-2017, 09:01 AM
Views 550
20-05-2017, 04:27 AM
Views 418
07-02-2017, 02:14 AM
Last Post by kam05
