JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Whats involved with a water pump replacement?
08-07-2018, 11:40 AM
Let's say that I've already got all coolant drained, I've removed the radiator and the serp belt is off. How involved is the water pump replacement?
Mine has a nice pink hair-do forming underneath it, so I think the seals may be perished or something.
08-07-2018, 11:40 AM #1
08-07-2018, 11:47 AM
Should have given a better thread title:
Not squirting as efficiently as possible
There's no fluid going round my system
I'm overheating with this amount of labour
08-07-2018, 11:47 AM #2
08-07-2018, 11:52 AM
Or "Help, my water squirter has pink pubes!!!"
08-07-2018, 11:52 AM #3
08-07-2018, 12:11 PM
here you go:
http://bahamutcars.free.fr/workshop/IS_9...o_0004.pdf
and refitting:
http://bahamutcars.free.fr/workshop/IS_9...o_0007.pdf
Edited 19-08-2011, 09:46 PM by Sparkystav.
08-07-2018, 12:29 PM
Cheers mate. My fears are confirmed - it says the timing belt needs to come off in order to do it. UGH
08-07-2018, 12:29 PM #5
08-07-2018, 11:54 PM
jimxms Cheers mate. My fears are confirmed - it says the timing belt needs to come off in order to do it. UGH
I was about to say, I expect it will, I've done them both on a couple of other Toyotas. If one needs changing, it makes sense to do both, while you're in there!
EDIT: When I say "I've done them," I mean I have paid a processional quite a lot of money to do them for me! This was a few years back though, I try to do everything myself now.
Edited 20-08-2011, 09:29 AM by Stoney.
08-07-2018, 11:54 PM #6
09-07-2018, 01:28 AM
Stoney I was about to say, I expect it will, I've done them both on a couple of other Toyotas. If one needs changing, it makes sense to do both, while you're in there!
Aye, thing is my belt was only changed 8k ago, so unless I go for a Greddy timing belt just for extra bling, it probably ain't worth swapping.
Maybe I'll just clean up the water pump instead and see if there's anywhere I can run some sealant over to stop the leak. Then I'll just get it done when my head is pulled for the new pistons.
Edited 20-08-2011, 11:04 AM by jimxms.
09-07-2018, 01:28 AM #7
09-07-2018, 01:35 AM
Jim it sounds like when the belt was change that has caused your problem with the water pump
09-07-2018, 01:35 AM #8
Views 236
24-07-2021, 05:07 AM
Last Post by phaebo
Views 208
04-10-2020, 11:23 AM
Last Post by ozzie b
Replies 31
Views 1,779
06-09-2017, 12:58 AM
Last Post by captain
Views 779
15-06-2017, 04:05 AM
Views 371
24-09-2016, 11:52 PM
Views 431
17-08-2016, 04:46 AM
Last Post by kam05
