JapCarForum Cars, Cars, Cars! General Car Maintenance Help Needed
Help Needed
Help Needed
14-07-2018, 01:31 PM
I keep getting a rubbing noise from my rear right wheel every time I turn left (under load).
I've taken the wheel off and had the disc off and the springs on the shoes had come off so I sorted that but I've still got the noise when I turn
Has anyone one got an idea what it could its doing my head in it sounds horriable when I'm out in the car
14-07-2018, 01:31 PM #1
14-07-2018, 01:36 PM
I had a similar noise on full lock turns, was the backing plate rubbing - ormi shoved it back off the brake discs a bit and no more noise...
Could be as simple as that?
14-07-2018, 01:36 PM #2
14-07-2018, 01:39 PM
Thanks Dave I hope it is as simple as that I have been thinking that but thought it can't be lol.
Its so annoying I just want it go
14-07-2018, 01:39 PM #3
14-07-2018, 01:50 PM
Fingers crossed that's all it is then bud Smile
14-07-2018, 01:50 PM #4
14-07-2018, 02:16 PM
it will be the backing plate jus not the one you see...remove the rear disk and you will see a groove on the inside of the disk now if you look theirs a lip attatched to the backing plate that runs inside the groove you'll find its that thats rubbing....just look fo the polished part on the lip that will show you were its rubbing....the fix hit it with a hammer.....sorry i mean adjust it lol
14-07-2018, 02:16 PM #5
15-07-2018, 12:28 AM
I think I may have the same problem! Is it causing any damage to drive it like that? I spose pics would not be something you had to hand? Brakes is one thing I have never played with much.
15-07-2018, 12:28 AM #6
Phil01
15-07-2018, 12:33 AM
we can sort it at JAE stoney if you are not too happy working on brakes, it will not do any harm as it is other than wear down the back plate, and that part is behind/inside the brake disc handbrake drum
Phil01
15-07-2018, 12:33 AM #7
15-07-2018, 12:34 AM
i think i know which part ur talking about.
Stoney if the rain stops ill get out there and have a go on mine and try to grab some pics as i go
15-07-2018, 12:34 AM #8
Phil01
15-07-2018, 12:42 AM
:offtopic: Pat are you going to JAE or who is the nearest member to you that is going this year as I still have the 4 black Lexus mats for you mate and they could get them to you
Phil01
15-07-2018, 12:42 AM #9
15-07-2018, 12:46 AM
Thanks guys.
Apparently no jacking up allowed at JAE Phil. (Not on site anyway.Wink)
15-07-2018, 12:46 AM #10
Thanks guys.
Views 915
28-09-2019, 10:07 AM
Last Post by mattlaw
Views 468
20-08-2019, 09:59 AM
Last Post by luke
Views 752
29-05-2019, 10:26 AM
Last Post by dazza8
Views 595
24-12-2018, 10:40 AM
Last Post by matt 'sexus' is200
Views 893
29-07-2018, 02:35 AM
Views 565
18-01-2018, 10:58 AM
Replies 22
Views 1,777
19-12-2017, 07:40 AM
