JapCarForum Cars, Cars, Cars! General Car Maintenance is200 - to 2JZGE engine - How/whats needed and cost?
Pages (3): 1 2 3 Next
gazzi123
16-03-2019, 12:52 PM
Hi all,
just really having an idea maybe to give my is200 a 2JZGE conversion like in the is300 or NA supra.
What is needed and what kind of price am i looking at:
obviously i know 2JZGE engine and W58 5 speed box. (or will standard is200 6speed be ok with upgraded clutch?
cheers Smile
gazzi123
16-03-2019, 12:52 PM #1
Hi all,
cheers Smile
16-03-2019, 01:08 PM
go and buy an IS300.
16-03-2019, 01:08 PM #2
16-03-2019, 01:16 PM
Buy a 300 IMHO or put a 2jzgte in. Don't mess about IMHO.
16-03-2019, 01:16 PM #3
Nuttaomen
16-03-2019, 01:18 PM
el_bandido go and buy an IS300.
Loud and clear boss Tongue
Nuttaomen
16-03-2019, 01:18 PM #4
gazzi123
16-03-2019, 01:22 PM
i dont want an auto.
gazzi123
16-03-2019, 01:22 PM #5
16-03-2019, 01:28 PM
it will be a LOT cheaper to convert an IS300 to manual than it will be to put a 2J in an IS200. Why shell out 6-7k converting an is200 when you can get an IS300 for £3-4k and swap a W58 into it? Engine swapping the IS200 is going to be a complete ball ache and completely not worth it if you want the end result identical to an IS300.
16-03-2019, 01:28 PM #6
gazzi123
16-03-2019, 01:38 PM
el_bandido it will be a LOT cheaper to convert an IS300 to manual than it will be to put a 2J in an IS200. Why shell out 6-7k converting an is200 when you can get an IS300 for £3-4k and swap a W58 into it? Engine swapping the IS200 is going to be a complete ball ache and completely not worth it if you want the end result identical to an IS300.
What would i need (parts wise) to convert from auto to manual - what price am i looking at?
gazzi123
16-03-2019, 01:38 PM #7
16-03-2019, 01:41 PM
if all you after is 211bhp just turbo or supercharge you current engine
16-03-2019, 01:41 PM #8
16-03-2019, 01:55 PM
gazzi123 What would i need (parts wise) to convert from auto to manual - what price am i looking at?
for a getrag v160 maual box brand new about 3 to 4000. http://www.suprastore.com/tosuge6sptrn.html
for a good second hand one about a grand or 2, then you need an adaptor for the shifter and a manual ecu, clutch a cluch peddle......
16-03-2019, 01:55 PM #9
16-03-2019, 02:08 PM
why would you put a getrag in a 215hp car? A W58 will be fine and should even bolt up to the 2jz shouldn't it? The yank 5 speeds were either a W58 or W55 I can't remember.
W58 will set you back a few hundred quid, you'd need a clutch kit for it.
Also a V160 will probably require cutting of the transmission tunnel.
Edited 26-04-2012, 11:42 PM by el_bandido.
16-03-2019, 02:08 PM #10
Views 339
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 697
28-06-2022, 04:42 AM
Last Post by MichaelTTE
Views 963
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,471
22-07-2021, 03:46 AM
Last Post by simon87
Views 592
17-03-2021, 09:57 AM
Last Post by iceman
Views 936
17-02-2021, 08:43 AM
Views 826
11-02-2021, 11:27 AM
Views 862
28-01-2021, 06:18 AM
Last Post by 1374lee
Views 1,042
27-01-2021, 04:28 PM
Views 924
27-01-2021, 01:37 AM
