JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Dumb Dumb question time
spud1973
23-07-2018, 05:03 AM
Where do you take the feed from for a boost gauge?? Standard tte kit
Ta Pete
spud1973
23-07-2018, 05:03 AM #1
Ta Pete
23-07-2018, 05:29 AM
Vacuum lines off the intake manifold mate.
23-07-2018, 05:29 AM #2
spud1973
23-07-2018, 05:34 AM
Nice one ta I was having a special moment have a rep point.
spud1973
23-07-2018, 05:34 AM #3
rob
27-07-2018, 09:38 AM
its actually the vac lines off the throttle body, there are 2 lines in that area. look for the line that goes into the side of the throttle body and then down to a sensor - its easy to see.
On the sensor 1 line will go down into the back of the engine area - do not use this one as it will not give you any reading.
rob
27-07-2018, 09:38 AM #4
27-07-2018, 09:47 AM
i have a bit of a problem with my set up. now i fitted the apexi boost control unit i seem to be getting no boost and very little wastegate open.
any ideas
27-07-2018, 09:47 AM #5
any ideas
27-07-2018, 10:55 AM
Here you go Pete :biggrin: Its the lower hose of the 2 on the lower part of the throttle body mate :thumbup1:
[Image: boostgaugefittinglex1.jpg]
[Image: boostgaugefittinglex2.jpg]
:thumbup:
Edited 07-09-2011, 08:30 PM by Bandit.
27-07-2018, 10:55 AM #6
:thumbup:
spud1973
27-07-2018, 11:20 AM
Cheers guys she's all done now and im getting just over 0.4 psi on full boost.
spud1973
27-07-2018, 11:20 AM #7
spud1973
27-07-2018, 11:22 AM
Bandit you are a legend:thumbup1:
spud1973
27-07-2018, 11:22 AM #8
27-07-2018, 02:50 PM
sorry to hijack this but this is how mine looks
[Image: info.jpg]
27-07-2018, 02:50 PM #9
[Image: info.jpg]
27-07-2018, 09:04 PM
jay_russell i have a bit of a problem with my set up. now i fitted the apexi boost control unit i seem to be getting no boost and very little wastegate open.
any ideas
Have you got the pipes on the wastegate right way round?
27-07-2018, 09:04 PM #10
any ideas
Views 481
04-11-2022, 05:54 AM
Views 759
02-08-2019, 12:10 PM
Last Post by Lance79
Replies 40
Views 2,333
27-01-2019, 02:46 PM
