JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning TTE front bumper + washers
Pages (4): 1 2 3 4 Next
russelllinn
25-06-2016, 06:40 AM
Have people seen the TTE bumper with headlight washer jets in?
I only ask as the bodyshop said that you could see all the mechanism through the grills by the fogs and they didn't think it looked very good so suggested I left them out which I don't mind doing but thought i'd seen them done.
Any thoughts?
russelllinn
25-06-2016, 06:40 AM #1
Any thoughts?
25-06-2016, 06:57 AM
Headlight washers should fit fine, given that the bumper has a similar shape to the standard one I don't see why the washer mechanism would be visible with one and not the other?
I don't have washers and actually prefer the cleaner lines without them but many do have them and that's something I've never heard before.
25-06-2016, 06:57 AM #2
russelllinn
25-06-2016, 07:00 AM
Yeah I thought others had had it done but without looking properly don't know whether they could see the mechanism through.
Unfortunately I am not about to be able to see for myself.
Liking the idea of the cleaner lines now though so may be for the best. cheers
russelllinn
25-06-2016, 07:00 AM #3
25-06-2016, 07:01 AM
yep when mine was replaced due to a moron reversing into it, the bodyshop ordered one direct through Lexus which came with the washer jets pre-cut out.
25-06-2016, 07:01 AM #4
russelllinn
25-06-2016, 07:03 AM
dan_harris yep when mine was replaced due to a moron reversing into it, the bodyshop ordered one direct through Lexus which came with the washer jets pre-cut out.
guessing you can't see the mechanism through the lower grills then Dan? or can you and you have to look hard?
russelllinn
25-06-2016, 07:03 AM #5
25-06-2016, 07:05 AM
I can't, unless you are nose to the bumper Smile
25-06-2016, 07:05 AM #6
russelllinn
25-06-2016, 07:08 AM
dan_harris I can't, unless you are nose to the bumper Smile
Smile hmm interesting wonder what the bodyshop are doing then. I will have to investigate!! albeit i expect i can retro-fit them at a later date.
Thanks
russelllinn
25-06-2016, 07:08 AM #7
Thanks
25-06-2016, 07:19 AM
i'll try and get a pic up for you mate Smile
25-06-2016, 07:19 AM #8
I would have thought the lower side grille bits are too low to show up the washer actuators etc ?
25-06-2016, 07:19 AM #9
russelllinn
25-06-2016, 07:23 AM
steviewevie I would have thought the lower side grille bits are too low to show up the washer actuators etc ?
You'd have thought so but unfortunately as I am not there can't say for sure, just hope they're looking at it right, can only think maybe the mesh is thinner than other peeps?
russelllinn
25-06-2016, 07:23 AM #10
Views 308
28-03-2021, 02:01 AM
Views 362
06-10-2019, 10:59 AM
Last Post by jomo
Views 626
24-08-2018, 04:44 AM
Last Post by Lexuslee
Views 824
01-07-2018, 07:31 AM
Last Post by bash6673
Replies 22
Views 1,438
28-01-2018, 03:48 AM
Last Post by karlp
Views 1,094
01-01-2017, 05:02 AM
Last Post by Asi
Views 517
21-10-2016, 01:46 PM
Last Post by Rolex
Views 644
17-06-2016, 10:56 PM
