JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Disc runout
Disc runout
Disc runout
25-06-2016, 09:16 AM
Just got the car back from a service, technically it sailed through again (great for a 7 year old car) with no work needed other than the service :thumbup1:
However, had them look at the vibration under braking I've had for a while, again no obvious fault but the inspection sheet talks about "disc runout". What is that?
The technician has scribbled a bit, but it looks like it says "advise disc runout check front" - anyone know what that's referring to and what I would need to have done? Picked the car up in a bit of a rush, so might have to ask tomorrow what exactly that means.
Also told me one of my shocks was mildly damp - but they've told me that for a few years now and every year told me it doesn't really need replacing so that's all good Smile
25-06-2016, 09:16 AM #1
25-06-2016, 09:19 AM
Disc runout is if the surface of the disc is uneven, e.g. has some higher points and some lower points. So he's recommending that the discs be checked to see if this is the problem on yours.
Garages normally have a special tool to measure this.
25-06-2016, 09:19 AM #2
RT
25-06-2016, 09:40 AM
Warped discs in layman terms.
Does your brake pedal move when braking? or do you just have a slight vibration?
RT
25-06-2016, 09:40 AM #3
25-06-2016, 10:30 AM
Ahh right, well I'm pretty sure it's not warped discs as I only had them done recently. They did also say to check whether something had been cleaned properly (of corrosion) before the discs were fitted - anyone know what they could be referring to?
Mentioned that the disc may not be sitting completely flush with whatever's behind it - it was done at WIM so must have been done right but might take it back to them to give it a once over.
Nope not the pedal at all, vibration is through the steering wheel - never feels unsafe but braking at motorway speed is really uncomfortable and even passengers can feel it through the car.
25-06-2016, 10:30 AM #4
RT
25-06-2016, 01:54 PM
The discs sit against the hubs, if corrosion is present there, then it may lead to a braking vibration.
Discs can warp in an instant, were they genuine Lexus items?
Could possibly be ball joints, but if it's been at Lexus I'd have hoped they'd of looked through everything thoroughly.
RT
25-06-2016, 01:54 PM #5
26-06-2016, 01:55 AM
Discs don't really actually "warp" as such, as I understand it, though. Unless they've been in very extreme conditions, e.g. on the race track.
What can happen though is that deposits can build up on parts of the disc, giving an uneven surface (which can make it seem like it's warped), and causing vibration.
With an auto this surface build-up can be more likely than a manual, with increased use of the brake to hold the car (vs the creep of the transmission) in traffic - e.g. if the discs/pads get hot and then you hold the brakes on in traffic.
26-06-2016, 01:55 AM #6
RT
26-06-2016, 05:12 AM
steviewevie Discs don't really actually "warp" as such, as I understand it, though.
You'd best tell Citroen then, as they recalled loads of theirs due to discs warping a few years back Big Grin
RT
26-06-2016, 05:12 AM #7
26-06-2016, 07:29 AM
Roadside Tech You'd best tell Citroen then, as they recalled loads of theirs due to discs warping a few years back Big Grin
Yeah, but if that was actual warping, was that due to a manufacturing fault, i.e. the discs either started off warped, or warped due to being designed/made badly ? Not really the same as most cases of disc "warping" (which aren't warping at all) that get mentioned on car forums etc.
26-06-2016, 07:29 AM #8
Views 411
29-07-2019, 09:39 AM
Replies 31
Views 2,294
24-07-2019, 02:42 PM
Last Post by sprinter2012
Views 386
15-01-2019, 05:15 AM
Last Post by avi_444
Views 713
18-08-2016, 08:29 PM
Last Post by cameron
Views 296
21-07-2016, 10:19 PM
