Is200 Traction Control Button
Hey guys, my pals TRC button next to the Snow button does nothing when you push it, no tell tale on the dash and no LED lighting up, the Snow button works fine.
I checked on the fuse covers in the footwell and didnt find anything of any use, then the one in the engine bay had an ETRC fuse which was 15A mini fuse but that seemed ok, i dont know if this is the correct fuse i was just summising it may be?
Does anyone know what else may cause it or whether there is a direct fuse for it that may of blown.
Barry Good call, how do you get into these tiny bulbs right inside the speedo then?
I know of the 5 main ones that people replace to change the speedo colour.
is trac working?? if its not then someone has taken the bulb out
not being sarcastic but the car will not do anything different when trac turned off, its when its on that the trac control function works, does it spin a wheel if you pull out of a sharp left or right turn on full power, if it does, trac aint working
does the 200 have another led to show operation in the switch ??
cant remember if they do or not
Marsdendean there is also no light on the TRC button . .. .
