JapCarForum Cars, Cars, Cars! Wheels & Tyres tyre size help
tyre size help
tyre size help
15-09-2018, 02:31 AM
hi all,
i have been offered a set of tyres for nothing from a mate but not sure if they would fit my standard 17" lexus alloy wheel
i have on the car 215/45/17 and these are 215/40/17 would this make any difference and would they be ok on the rim
please help i useless when it comes to tyres
15-09-2018, 02:31 AM #1
hi all,
15-09-2018, 02:42 AM
the number 40 is the sidewall profile mate, so it will be 5mm lower than the 45 you currently have, will fit, just means a slightly harsher ride! but that is well and truley compensated for when they are free Big Grin
Edited 27-10-2011, 12:17 PM by SHAHZ.
15-09-2018, 02:42 AM #2
15-09-2018, 02:57 AM
thanks Shahz like i said im useless with tyre info lol
15-09-2018, 02:57 AM #3
15-09-2018, 03:46 AM
Will fit just on the wheels perfectly mate.
On the plus side, you will have a slightly lower, though slightly harsher ride, and this should boost both handling and acceleration a tiny bit. On the downside, the tyres may look a bit skinny and the overall wheel size may look too small, your speedo will read under a couple of percent and top speed will drop marginally.
Info for you below:
(The forum always murders table formatting! The first figure is for the stock tyre and the second figure for your proposed new one, for each respective aspect.)
Diameter: 625.3mm 603.8mm
Circumference: 1964.4mm 1896.9mm
Speedo error: 0% 3.56%
Reading at 30mph: 30mph 31.07mph
Reading at 60mph: 60mph 62.14mph
Ride height loss: 0mm 10.75mm
Arch gap increase: 0mm 10.75mm
Edited 27-10-2011, 01:21 PM by Stoney.
15-09-2018, 03:46 AM #4
Info for you below:
15-09-2018, 03:56 AM
SHAHZ the number 40 is the sidewall profile mate, so it will be 5mm lower than the 45 you currently have, will fit, just means a slightly harsher ride! but that is well and truley compensated for when they are free Big Grin
You are right that the second number is height, but it is not in mm. It is as a percentage of the width. So 215/45/17 is 215mm wide on a 17" rim, but the sidewall height is 215mm x 45% = 96.75mm. 215/40/17 is 215mm wide on a 17" rim but with a sidewall height of 215mm x 40% = 86mm. A difference in this case of 10.75mm. This is each side, so overall the wheels will be 21.5mm smaller in diameter, though only 10.75mm difference in ride height, seeing as only the half of the wheel below the axle effects the height of the car, the other 10.75mm difference is in the extended gap between the top of the tyre and the arch.
Effectively; the car will drive like it's been lowered 1cm, but look like it's been raised 1cm!
15-09-2018, 03:56 AM #5
15-09-2018, 09:57 AM
No side wall it a percentage of the tyre width.
15-09-2018, 09:57 AM #6
15-09-2018, 10:07 AM
thanks for all the info on what is what regarding tyres.
and im happy that they will fit so ill be sorting these out soon before the weather gets any worse
15-09-2018, 10:07 AM #7
15-09-2018, 10:28 AM
2tongues No side wall it a percentage of the tyre width.
Is there an echo in here? Smile
15-09-2018, 10:28 AM #8
15-09-2018, 10:44 AM
Stoney Is there an echo in here? Smile
I missed your post as I just hit quote without reading the thread - I do that its big and clever:whistling:
15-09-2018, 10:44 AM #9
15-09-2018, 10:46 AM
it's so crazy with tyre sizes,
the first 3 numbers are in mm ( 215)
the next 2 numbers are a % of the first
and the last 2 numbers are in inches
what a mess Smile and i work with this every day
15-09-2018, 10:46 AM #10
Views 1,817
14-07-2021, 01:55 PM
Views 703
28-07-2018, 06:12 PM
Views 1,312
06-02-2018, 01:36 PM
Last Post by danielson
Views 811
05-02-2018, 11:55 AM
Last Post by CIH
Views 983
24-08-2017, 11:43 AM
Views 1,759
06-04-2017, 09:25 PM
Views 701
10-10-2016, 03:14 AM
Last Post by TommyH
Views 873
13-08-2016, 02:05 AM
Views 538
09-05-2016, 10:26 AM
Views 501
09-05-2016, 10:24 AM
