JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning HID headlights
HID headlights
HID headlights
Pages (3): 1 2 3 Next
christopherhughes
01-10-2018, 06:04 AM
Hi guys, can anyone help. i'm after changing my standard headleights for HID one. is it better to change both main and dipped beams, and where is the best place to get them from.
thanks
christopherhughes
01-10-2018, 06:04 AM #1
thanks
01-10-2018, 06:17 AM
christopherhughes Hi guys, can anyone help. i'm after changing my standard headleights for HID one. is it better to change both main and dipped beams, and where is the best place to get them from.
thanks
Having personal experience of changing both, my advice/experience is as follows...
Pro's:
  • Huge increase in light output (3x Brigher for 35W, 4x Brighter for 55w) I've got 35W kits in main and dipped and they are more than bright enough.
  • Looks good, you can choose anything from JDM yellow right up to purple if you want. But most go for 5000K (pure white) or 6000K (white with a bluey tint)
  • Reduced power consumption, if you use the 35W ballasts you are saving yourself 80W of current draw (assuming you do all 4 lights) so less stress on the battery/alternator.
Con's:
  • Can be expensive, although there are some ridiculously cheap kits out now (some of them are even cheaper that a pair of good bulbs!)
  • This isn't an issue with the dipped beam because they come on and stay on, but HID's take around 10 seconds to warm up to full brightness from a cold start. But once they have been used once, they normally come on at full brightness instantly or after a 1-2 quick warm up. But either way, I've found the light output is fantastic, and matches that of a normal halogen bulb even during the warmup phase.
The one thing I would say is the main reason I changed the full beam as well is because I didn't like the 'murky' bit you got in the light pattern where the nice white/blue HID light met the normal colour yellowy light from the OEM bulbs.
01-10-2018, 06:17 AM #2
thanks
Pro's:
Con's:
01-10-2018, 06:20 AM
If you get good quality HIDS just on dipped you will find there is little point in using high beam, so save your money and just do the dipped.
01-10-2018, 06:20 AM #3
01-10-2018, 07:38 AM
2tongues If you get good quality HIDS just on dipped you will find there is little point in using high beam, so save your money and just do the dipped.
I agree, most of the time I don't bother using my main beams unless it's late at night and there's little chance of oncoming traffic.
The only reason I changed them at all was so the colour matched the dipped beams becase I'm fussy like that. lol
01-10-2018, 07:38 AM #4
christopherhughes
01-10-2018, 10:49 AM
thanks for the advice, i think i'll just changed the dipped ones first see how i feel after that. is there any particular type to use or are the ones at around £50 on flee bay ok?
cheers
christopherhughes
01-10-2018, 10:49 AM #5
cheers
Talisker
02-10-2018, 12:34 PM
I've got HID's for my main and dipped beam - 5000k dipped, 6000k main both 35w.
I got them both off ebay for £40 each and they've never missed a beat, more than happy with them.
Well impressed with the main beam in particular, yeah it takes a few seconds to warm up once they're there, they light up the road like daylight and you can see the distinct outline of the reflector up ahead.
Talisker
02-10-2018, 12:34 PM #6
christopherhughes
04-10-2018, 09:22 AM
thats great i'll get some ordered today, get rid of the candles that seem to be in there at the moment. thanks.
christopherhughes
04-10-2018, 09:22 AM #7
clossie
04-10-2018, 09:29 AM
Has anyone seen/used the hid projector kits now available for hid's direct?
clossie
04-10-2018, 09:29 AM #8
Barry
01-12-2019, 12:46 PM
Save making a new thread just though id ask here, will these be ok for the dipped beam on my IS200? And relatively easy to fit and wire i assume?
http://www.ebay.co.uk/itm/140827242151?s...1423.l2649
Barry
01-12-2019, 12:46 PM #9
posty
01-12-2019, 12:57 PM
Yes mate that is the kit, same one that I have.
Will take you a maximum of 10 minutes to fit!
posty
01-12-2019, 12:57 PM #10
Views 323
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 344
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 1,155
29-03-2019, 10:58 AM
Views 776
13-10-2018, 02:54 PM
Views 1,058
14-04-2018, 11:00 PM
Last Post by James S
Replies 18
Views 1,393
03-02-2018, 03:27 PM
Last Post by DTD
Views 1,188
22-11-2017, 04:36 PM
Last Post by D6NGR..
Replies 27
Views 2,011
21-07-2017, 02:47 PM
Last Post by Phil01
Replies 40
Views 2,391
03-09-2016, 09:10 AM
