JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning projector headlights
christopherhughes
13-10-2018, 12:06 AM
Hi all, i've been looking at buying some projector headlights form USA, these are for the is300, however spoke to the guy over there and he said a very small amount needs trimming off the top of the lights to make them fit the is200. Has anyone fitted these or is300 lights to the 200? Cheers
christopherhughes
13-10-2018, 12:06 AM #1
13-10-2018, 01:06 AM
i have heard the fittings are slightly different, Ormi was looking into doing the same sort of project using is300 lights so he may have some info on how to install them, but also remember the light scatter will be wrong as they drive on the wrong side of the road so the light will shine in the wrong direction and will fail MOT if you do not correct the angle of light.
13-10-2018, 01:06 AM #2
christopherhughes
13-10-2018, 01:48 AM
Never thought of that thanks
christopherhughes
13-10-2018, 01:48 AM #3
13-10-2018, 06:44 AM
It is unusual for US cars to have angled lights,they are usually set to point straight forwards, so you may be lucky and they may be easy to angle to UK spec.
13-10-2018, 06:44 AM #4
13-10-2018, 07:47 AM
they fit in without problems and are very adjustable, the will go both ways, mine went in without problems, but they sometimes need the oem hid ballests like mine, these cost 90 dollars each
13-10-2018, 07:47 AM #5
P.Lindblom
13-10-2018, 08:55 AM
Here's the difference between a 1st gen IS HID headlight (top) and a halogen headlight (bottom)
[Image: dsc7729fix.jpg]
And this is what you have to cut to be able to fit an IS300 headlight to an IS200 without factory xenon headlights.
[Image: dsc7734fix.jpg]
P.Lindblom
13-10-2018, 08:55 AM #6
13-10-2018, 09:08 AM
opps yer mine are oem hids so they fitted without removing anything
13-10-2018, 09:08 AM #7
13-10-2018, 10:42 AM
you can buy a projector kit that fits straight in to the headlight(you do need to split the lights though)
13-10-2018, 10:42 AM #8
13-10-2018, 02:54 PM
what happened to that thread with all the info on the projector shrouds and stuff? I can't seem to find it.
13-10-2018, 02:54 PM #9
Views 251
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 283
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Replies 22
Views 1,177
09-07-2020, 04:04 PM
Last Post by powerdbyis
Views 1,010
29-03-2019, 10:58 AM
Views 899
14-04-2018, 11:00 PM
Last Post by James S
Replies 18
Views 1,167
03-02-2018, 03:27 PM
Last Post by DTD
Views 1,050
22-11-2017, 04:36 PM
Last Post by D6NGR..
Replies 27
Views 1,732
21-07-2017, 02:47 PM
Last Post by Phil01
Replies 40
Views 2,036
03-09-2016, 09:10 AM
